1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Accessing Elements of a Waveform Record
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Tue, 2 Jul 2019 21:28:05 +0000
Hi Chris,
On 7/2/19 3:43 PM, Christopher Herrmann via Tech-talk wrote:
Currently, I have a waveform record that holds 10 different values.
I was wondering if there was any way to reference an individual element
in that waveform record.
What version of Base are you running, and what is actually trying to access the element (CA client, another record, etc)?
My best solution so far is to use the "aCalcOut"
record and have it process, then output, a single hard coded value.
Something like this for the "calc" field:
field(CALC, "AA[0,0]") or field(CALC, "AA[1,1]")
While this is fine for a few elements, I may need to be able to access up
to 30 different values in a single waveform record individually.
Are there any clever or streamline ways to go about this?
If you're running Base-3.15.x or later there is (through Channel Access or a CA link), take a look at the array server-side filter which is documented here.
You could also look at the subArray record, which extracts parts of an array at a specific length and offset. This comes with all Base versions.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Accessing Elements of a Waveform Record Christopher Herrmann via Tech-talk
Prev: Accessing Elements of a Waveform Record Christopher Herrmann via Tech-talk
Next: BNL Job Opening in NSLS-II Controls Anton Derbenev via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: RE: Accessing Elements of a Waveform Record Steiner, Mathias via Tech-talk
ANJ, 02 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
