1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Usage of pvlist
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: Tech-Talk <[email protected]>
Date: Wed, 3 Jul 2019 15:10:51 +0000
I am trying to use pvlist to discover all PVs served thru pvAccess.
Let’s say that I have a few soft EPICS7 IOC running on one machine on different ports, for example:
$ pvlist
GUID 0xA21BC25C0000000083EAFA2C, version 1: tcp@[192.168.10.20:60605]
GUID 0xBA1BC25C00000000ACD90824, version 1: tcp@[192.168.10.20:60607]
GUID 0xBBB91C5D000000005646DE0A, version 1: tcp@[192.168.10.20:58861]
GUID 0xD71BC25C00000000E55F910B, version 1: tcp@[192.168.10.20:60608]
I can use pvlist IP:port to get the PVs served thru QSRV on that specific port.
If I use “pvlist IP”, it gives me the PVs only on the first port it found (looks like).
Is that a way to find all PVs on different ports instead of looping thru all ports individually?
Guobao
Re: Usage of pvlist Johnson, Andrew N. via Tech-talk
Prev: pvDatabase Tutorial Marty Kraimer via Tech-talk
Next: Re: [EXTERNAL] Beckhoff BK9000 support survey Wallace, Alex via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Usage of pvlist Johnson, Andrew N. via Tech-talk
ANJ, 03 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
