1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: USBTMC Device can not autoConnect
To: 'Eric Norum' <[email protected]>, Christopher Herrmann <[email protected]>
Date: Thu, 18 Jul 2019 15:55:16 +0000
On Centos7 the only packages available that contain libusb-1.0.so are the libusbx ones:
corvette:local/epics-devel/base-7.0.2>sudo yum provides '*/libusb-1.0.so*'
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: ftp.usf.edu
* epel: d2lzkl7pfhq30w.cloudfront.net
* extras: mirror.cs.vt.edu
* updates: ftp.ussg.iu.edu
libusbx-1.0.21-1.el7.i686 : Library for accessing USB devices
Repo        : base
Matched from:
Filename    : /usr/lib/libusb-1.0.so.0.1.0
libusbx-1.0.21-1.el7.x86_64 : Library for accessing USB devices
Repo        : base
Matched from:
Filename    : /usr/lib64/libusb-1.0.so.0.1.0
libusbx-devel-1.0.21-1.el7.i686 : Development files for libusbx
Repo        : base
Matched from:
libusbx-devel-1.0.21-1.el7.x86_64 : Development files for libusbx
Repo        : base
Matched from:
Repo        : @base
Matched from:
Repo        : @base
Matched from:
Repo        : @base
Matched from:
Repo        : @base
Matched from:
Those are installed on my system.  But I don’t have any USBTMC devices to test.
From: [email protected] <[email protected]> On Behalf Of Eric Norum via Tech-talk
Sent: Wednesday, July 17, 2019 1:15 PM
To: Christopher Herrmann <[email protected]>
Cc: Marty Kraimer via Tech-talk <[email protected]>
Subject: Re: USBTMC Device can not autoConnect
On Jul 17, 2019, at 11:00 AM, Christopher Herrmann <[email protected]> wrote:
Both systems have the same version of EPICS retrieved from github. I also believe that both systems have the same version of ASYN.
Is the version number listed somewhere in the module so that I can double check?
Check your application configure/RELEASE file.
Here for example are the salient lines from a test IOC here:
ASYN       = /eda/epics/R3.15.5/modules/soft/asyn/asyn4-31
AUTOSAVE   = /eda/epics/R3.15.5/modules/soft/autosave/autosave-5-1
IOCEXIT    = /eda/epics/R3.15.5/modules/soft/iocExit/iocExit-2-0
EPICS_BASE = /eda/epics/R3.15.5/base
I can't remember if I got them from the module github
page or if I pulled them out of synApps and compiled them. Is there a preferred method?
The libusb question gets a bit interesting. The first system was debian based and so I installed libusb-1.0 via apt.
Running dpkg --get-selections | grep libusb gives me this output on the debian system.
libhidapi-libusb0:amd64 install
libusb-0.1-4:amd64 install
libusb-1.0-0:amd64 install
libusb-1.0-0:i386 install
libusb-1.0-0-dev:amd64 install
libusb-1.0-doc install
libusb-dev install
libusbmuxd4:amd64 install
When I was compiling asyn for the Scientific Linux system it kept complaining that <libusb/libusb-1.0.h> was not found.
I had someone install what I thought was the correct package, but still got the same error when compiling.
Someone else then mentioned something about libusb vs libusbx. Here is the output from running rpm -qa | grep libusb
on the Scientific Linux system:
libusbmuxd-1.0.10-5.el7.x86_64
libusb-0.1.4-3.el7.x86_64
libusb-devel-0.1.4-3.el7.x86_64
Could that have something to do with it?
I’ve not used libusbx and it sounds like it really isn’t the right package to use.
From the libusb wiki:
libusb.org was the original home for libusb project. Now it still exists but the information and code are quite outdated.
libusb.info is the current home page for libusb project.
libusbx was a fork of libusb and libusbx.org is its website. As of 2014.01.26, libusbx project has been fully merged back into libusb and is being discontinued. libusbx.org is no longer related to libusb project.
Eric Norum
[email protected]
USBTMC Device can not autoConnect Christopher Herrmann via Tech-talk
Re: USBTMC Device can not autoConnect Eric Norum via Tech-talk
Prev: Re: pasynOctetSyncIO flushing with drvAsynIPPortConfigure Hinko Kocevar via Tech-talk
Next: RE: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: USBTMC Device can not autoConnect Eric Norum via Tech-talk
Next: Add widgets to Phoebus Hasbroucq Dorian via Tech-talk
ANJ, 19 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
