1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: USBTMC Device can not autoConnect
From: Christopher Herrmann via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 17 Jul 2019 11:03:30 -0400
Hello,
I am currently trying to interface with a Keithly 2230G multichannel power supply over USBTMC.
When I plug in the device it appears at "/dev/usbtmc0" and I have the permissions set that
I should be able to access it. However, when running the IOC I get the following message:
usbtmcConfigure("U0")
No device information specified.  Will connect to first USB TMC device found.
2019/07/17 10:51:18.202 U0 -1 autoConnect could not connect
I am in the process of transferring my IOC from one computer to another. This command would
just magically work on the previous device, but not on this one.
Any suggestions would be appreciated.
~ Chris
Re: USBTMC Device can not autoConnect Eric Norum via Tech-talk
Prev: Re: pvGet in Sequence does not work with incorrect size Benjamin Franksen via Tech-talk
Next: Re: SmarAct MCS2 ASCII-based IOC Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Next: Re: USBTMC Device can not autoConnect Eric Norum via Tech-talk
ANJ, 19 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
