1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SmarAct MCS2 ASCII-based IOC
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Stubbs Scott Allen (PSI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 17 Jul 2019 15:45:26 +0000
David Vine recently wrote an asyn motor driver for the MCS2 that uses
ASCII commands instead of the vendor's C++ library.  The driver can be
found in the motorSmarAct module:
   https://github.com/epics-motor/motorSmarAct
The README for the MCS2 support is here:
https://github.com/epics-motor/motorSmarAct/blob/master/smarActApp/src/README.SmarActMCS2
Kevin
On 7/17/19 4:31 AM, Stubbs Scott Allen (PSI) via Tech-talk wrote:
> Dear Tech-talkers,
> As it seems there is no fully ASCII-‘byte stream’ based IOC for the
> SmarAct MCS2 (at least not available publicly) I am pleased to present
> our first attempt at one using StreamDevice.  I began developing it
> based on our MCS IOC when we believed we would need to integrate the
> MCS2 for a particular project. As we purchased the MCS in the end, and
> we have no MCS2 units for testing, our development has also stopped for
> the time being.
> Comments, forks, additions and/or fixes welcome. Note that while we have
> put some effort in converting commands and EPICS records from the MCS
> (e.g. positioner types, amplifier voltage…) this is a completely
> untested IOC and still based around our internal PSI build system.
> However, the db/ and cfg/ files can be considered universal.  If I get
> permission from SmarAct I will publish their full documentation here as
> well.
> Also, a special thank you to SLAC colleagues who gave me a starting
> point for the protocol file =)
> Link:
> https://github.com/paulscherrerinstitute/smaract_mcs2/
> Greetings from Switzerland,
> Scott
> __________________________________________
> Scott Stubbs
> Controls Group
> Paul Scherrer Institut
> 5232 Villigen PSI
> Schweiz
> Telefon: +41 56 310 21 65
> E-Mail: [email protected]
RE: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Prev: USBTMC Device can not autoConnect Christopher Herrmann via Tech-talk
Next: Re: USBTMC Device can not autoConnect Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Next: RE: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
ANJ, 19 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
