1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: SmarAct MCS2 ASCII-based IOC
From: "Stubbs Scott Allen \(PSI\) via Tech-talk" <[email protected]>
Date: Wed, 17 Jul 2019 09:31:29 +0000
Dear Tech-talkers,
As it seems there is no fully ASCII-‘byte stream’ based IOC for the SmarAct MCS2 (at least not available publicly) I am pleased to present our first attempt at one using StreamDevice.  I began developing it based on our MCS IOC when we believed we would need to integrate the MCS2 for a particular project.  As we purchased the MCS in the end, and we have no MCS2 units for testing, our development has also stopped for the time being.
Comments, forks, additions and/or fixes welcome.  Note that while we have put some effort in converting commands and EPICS records from the MCS (e.g. positioner types, amplifier voltage…) this is a completely untested IOC and still based around our internal PSI build system.  However, the db/ and cfg/ files can be considered universal.  If I get permission from SmarAct I will publish their full documentation here as well.
Also, a special thank you to SLAC colleagues who gave me a starting point for the protocol file =)
Link:
https://github.com/paulscherrerinstitute/smaract_mcs2/
Greetings from Switzerland,
Scott
__________________________________________
Scott Stubbs
Controls Group
Paul Scherrer Institut
5232 Villigen PSI
Schweiz
Telefon: +41 56 310 21 65
E-Mail: [email protected]
Re: SmarAct MCS2 ASCII-based IOC Peterson, Kevin M. via Tech-talk
Prev: Re: monitoring field device Pierrick M Hanlet via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Benjamin Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: SmarAct MCS2 ASCII-based IOC Peterson, Kevin M. via Tech-talk
ANJ, 17 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
