1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvGet in Sequence does not work with incorrect size
From: Benjamin Franksen via Tech-talk <[email protected]>
To: Simon Reiter <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 17 Jul 2019 12:42:52 +0200
Am 16.07.19 um 16:43 schrieb Simon Reiter via Tech-talk:
> using the sequencer in v2.2 and EPICS 3.14:
> The sequence does get a waveform, does a calculation and pushes an
> array out to another waveform PV.
> pvGet() is not working and runs in a timeout in case the size of the
> unsigned char array does not exactly fit the size of the waveform.
> Instead, assigning and monitoring the PV in the beginning works fine.
> Is this on purpose? The monitoring of the is not necessary.
Hi Simon
This should not happen. I will try to reproduce your problem and add a
test case. Dealing with arrays in EPICS is awfully hard, so I guess it's
quite possible that this is a bug in the Sequencer.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: pvGet in Sequence does not work with incorrect size Simon Reiter via Tech-talk
Prev: SmarAct MCS2 ASCII-based IOC Stubbs Scott Allen (PSI) via Tech-talk
Next: USBTMC Device can not autoConnect Christopher Herrmann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: pvGet in Sequence does not work with incorrect size Simon Reiter via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Simon Reiter via Tech-talk
ANJ, 02 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
