1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: pvGet in Sequence does not work with incorrect size
From: Simon Reiter via Tech-talk <[email protected]>
Date: Tue, 16 Jul 2019 16:43:57 +0200
using the sequencer in v2.2 and EPICS 3.14:
The sequence does get a waveform, does a calculation and pushes an
array out to another waveform PV.
pvGet() is not working and runs in a timeout in case the size of the
unsigned char array does not exactly fit the size of the waveform.
Instead, assigning and monitoring the PV in the beginning works fine.
Is this on purpose? The monitoring of the is not necessary.
Best regards,
Simon
Re: pvGet in Sequence does not work with incorrect size Benjamin Franksen via Tech-talk
Prev: Re: updating ADAndor from RHEL6 to RHEL7 ben.bradnick--- via Tech-talk
Next: monitoring field device Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problems with ioc app building with asyn Mark Rivers via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Benjamin Franksen via Tech-talk
ANJ, 17 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
