1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS 3.15 mlockall()/dbThreadRealtimeLock high memory usage
From: Lucas Russo via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 24 Jul 2019 14:24:00 -0300
Hello everyone,
Recently, I noticed one of my IOCs consuming a lot more memory right after IOC startup (from linux "top" command, RES field, which I know it's not a good estimate sometimes, but still...) after upgrading it from EPICS base 3.14.12.6 to 3.15.6. All of the other EPICS modules was kept in the same version:
asyn: R4-35
areaDetector: R3-6
Even with other IOCs, areaDetector ADSimDetector, for instance, the memory consumption after IOC startup was way higher than before. For example:
EPICS 3.14 ADSimDetector: RES = 356502 MiB
EPICS 3.15 ADSimDetector: RES = 48613 MiB
After doing some debugging and memory profiling I saw that the ADSimDetector IOC running with EPICS 3.15 had the "VMLck" field from /proc/<pid>/status with:
VmLck: 4586544 kB
And the IOC running EPICS 3.14 had:
VmLck: 0  kB
Taking a look at the Release Notes there was a mention of "mlockall" being moved to some other place ("Moved mlockall() into its own epicsThread routine", "Changes made between 3.15.3 and 3.15.4")
I changed the "dbThreadRealtimeLock" variable from 1 (default) to 0 and the memory consumption dropped back to ~48613 MiB. Even after running the IOC for some time, doing some large acquisitions, the memory consumption was not close to the 356502 MiB.
Can anyone help me understand if this is somewhat expected?
And wouldn't it be better to have the variable dbThreadRealtimeLock with the default value of 0, instead of 1?
Cheers and Regards,
Lucas
Re: EPICS 3.15 mlockall()/dbThreadRealtimeLock high memory usage Lucas Russo via Tech-talk
Re: EPICS 3.15 mlockall()/dbThreadRealtimeLock high memory usage Till Straumann via Tech-talk
Prev: Alarm system setup enum riz via Tech-talk
Next: Re: EPICS 3.15 mlockall()/dbThreadRealtimeLock high memory usage Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alarm system setup Shroff, Kunal via Tech-talk
ANJ, 01 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
