1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with ADURL reading .jpg image from server
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Wed, 31 Jul 2019 15:25:28 +0000
Hi Mark,
The url we are using does actually have the .jpg extention: http://xf28ida-vsrv01.cs.nsls2.local/jpg/1/image.jpg
I can also confirm that running wget on the same url does result in a .jpg file on the local machine, which can then be read
by the IOC without issue.
When I enter the url into a web browser it also recognizes it as a jpeg file and displays its dimensions in the title bar.
When I press 'Acquire' to start image acquisition the IOC freezes for some time, and then goes back into the done state after
printing the error message.
Thanks for the quick response,
Jakub Wlodek
Sent: Wednesday, July 31, 2019 11:19 AM
To: Wlodek, Jakub <[email protected]>
Cc: [email protected] <[email protected]>
Hi Jakob,
I believe that GraphicsMagick uses the file extension to determine the format. It looks like URL does not have a .jpg extension?
Sent from my iPhone
On Jul 31, 2019, at 8:56 AM, Wlodek, Jakub via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi all,
I have been working with the ADURL driver to set up an IOC for an analog camera here at NSLS2. I have the IOC set up and running, and I can read .jpg files without issue locally on the ioc server.
However, when I enter the URL for the image coming from the camera, the driver does not get images, and when I stop acquisition, I get the following error message:
10:48:39 74:30 39.180u 3390 constitute.c/GmReadImage/1535/MissingDelegate:
  No decode delegate for this image format (/tmp/gmmxs23m)
2019/07/31 10:48:39.033 URLDriver:readImage: error reading URL="" No decode delegate for this image format (/tmp/gmmxs23m) reported by ../constitute.c:1535 (GmReadImage)
I tested putting the url I gave the IOC into a web browser and it correctly opened a jpeg image. I also downloaded said image to the local machine and pointed at it: /home/jwlodek/image.jpg, and the ADURL IOC
processed it without issue. My guess is that when reading the url from the server the ADURL driver is not actually seeing a .jpg file, which is causing it to say that there doesn't exist a decode format for it.
Has anyone else ran into this issue before, and if so would you be able to share the solution?
Jakub Wlodek
Re: Problem with ADURL reading .jpg image from server Mark Rivers via Tech-talk
Problem with ADURL reading .jpg image from server Wlodek, Jakub via Tech-talk
Prev: Re: Problem with ADURL reading .jpg image from server Mark Rivers via Tech-talk
Next: Re: Problem with ADURL reading .jpg image from server Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
