1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: spec epics_caget not working
To: "Miceli, Antonino" <[email protected]>
Date: Mon, 5 Aug 2019 12:11:41 +0000
Hi Nino,
Is there perhaps a script that is run to start spec that is setting some EPICS_CA... environment variables? I've been told that there are no such variables set in the Linux shell running caget.
spec can connect to another areaDetector IOC (ADPilatus) correct?
Can medm and python connect to the ADLambda IOC?
Sent from my iPhone
On Aug 5, 2019, at 12:55 AM, Miceli, Antonino via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
We have an EPICS areadetector soft IOC (AD core 3.6) running on a Debian PC for a Lambda detector. We are trying to control with spec, but spec's epics_caget commands return errors (e.g., "Not Connected"). When we run caget from the PC running spec, it works fine.
Any suggestions? I know this is not a spec mailing list, but I figure this is the next best thing!
Nino
Re: spec epics_caget not working Kirchman, Jeff via Tech-talk
spec epics_caget not working Miceli, Antonino via Tech-talk
Prev: RE: [motorPIGCS2] can't turn on servo state of PI E-712 Chiang, Liang-Chih [江良志] via Tech-talk
Next: Question about EPICS7 + QSRV Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: spec epics_caget not working Miceli, Antonino via Tech-talk
Next: Re: spec epics_caget not working Kirchman, Jeff via Tech-talk
ANJ, 05 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
