1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: spec epics_caget not working
From: "Kirchman, Jeff via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, "Miceli, Antonino" <[email protected]>
Date: Mon, 5 Aug 2019 13:43:38 +0000
Mark,
A difference in ENV variables was my thought as well.  But the scientist
told us that he could use a unix system call inside spec to caget the
Lambda PVs.
And he also says this particular Linux host is able to access all other
PVs such as the storage ring or other devices.
-Jeff
On 8/5/2019 7:11 AM, Mark Rivers via Tech-talk wrote:
> Hi Nino,
> Is there perhaps a script that is run to start spec that is setting some EPICS_CA... environment variables? I've been told that there are no such variables set in the Linux shell running caget.
> spec can connect to another areaDetector IOC (ADPilatus) correct?
> Can medm and python connect to the ADLambda IOC?
> Mark
> Sent from my iPhone
> On Aug 5, 2019, at 12:55 AM, Miceli, Antonino via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
> Hi,
> We have an EPICS areadetector soft IOC (AD core 3.6) running on a Debian PC for a Lambda detector. We are trying to control with spec, but spec's epics_caget commands return errors (e.g., "Not Connected"). When we run caget from the PC running spec, it works fine.
> Any suggestions? I know this is not a spec mailing list, but I figure this is the next best thing!
> Thanks,
> Nino
Re: spec epics_caget not working Ralph Lange via Tech-talk
spec epics_caget not working Miceli, Antonino via Tech-talk
Re: spec epics_caget not working Mark Rivers via Tech-talk
Prev: Question about EPICS7 + QSRV Florian Feldbauer via Tech-talk
Next: Re: spec epics_caget not working Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: spec epics_caget not working Mark Rivers via Tech-talk
ANJ, 05 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
