1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: comment a field with a macro
From: Alfio Rizzo via Tech-talk <[email protected]>
Date: Wed, 7 Aug 2019 15:17:43 +0000
I see some strange behavior when I want to comment
a field in a record if there there are different macros in it
E.g.
record(ai, "$(user):PiraniGauge") {
  field(DESC, "Readback form Pirani Gauge")
  field(EGU,  "Torr")
  field(VAL, 4e-07)
  #field(SIML, "$(test):SimulationMode")
When then I load the db,
I must defined also the macro $test even if I don’t use it (its commented),
Otherwise I will get this warning from the iocsh
macLib: macro test is undefined (expanding string #  field(SIML, "$(test):SimulationMode")
i.e. I have to write
dbLoadRecords("piranig.db","user=me, test=mytest")
Is this normal ? why it does not skip the entire commented line ?
Thanks
Best
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
Re: comment a field with a macro Kasemir, Kay via Tech-talk
Prev: Re: [motorPIGCS2] can't turn on servo state of PI E-712 Chiang, Liang-Chih [江良志] via Tech-talk
Next: Re: comment a field with a macro Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about EPICS7 + QSRV Michael Davidsaver via Tech-talk
ANJ, 07 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
