1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Undefined Timestamp on Motor Record
From: William Layne via Tech-talk <[email protected]>
To: Dominic Oram - UKRI STFC <[email protected]>
Cc: [email protected]
Date: Thu, 15 Aug 2019 19:54:39 -0400
I have little experience with the motorRecord, so apologies if it's not supported.
 I would try setting the "PINI" field to "TRUE". That is how I've handled this issue for standard records.
On Thu, Aug 15, 2019, 1:16 PM Dominic Oram - UKRI STFC via Tech-talk <[email protected]> wrote:
Hello,
I’m in the process of writing a model 3 motor driver using version 6-11 of the motor record.
I have found some unexpected behaviour on initialisation if the driver has no device connected.
It appears the motor stays in the following state unless a parameter is updated at some point after initialisation (I’m not sure when):
caget –a MOTOR
MOTOR        <undefined> 0
If I have no device connected I set motorStatusCommsError_ to 1 on the first call to poll(). However, because all subsequent calls to poll() do not change any parameters I stay in the above state. I would instead expect to see something like:
caget –a MOTOR
MOTOR        2019-08-15 15:57:41.931650 0 COMM INVALID
as in the undefined timestamp situation it’s not obvious to users that there is a comm error.
Setting motorStatusCommsError_ to 1 at some time after initialisation does give me the expected state.
Is this actually expected behaviour? Do other people see something similar?
Dominic Oram
Senior Software Engineer
Experimental Controls
ISIS Neutron and Muon Source
Undefined Timestamp on Motor Record Dominic Oram - UKRI STFC via Tech-talk
Prev: Re: Undefined Timestamp on Motor Record Peterson, Kevin M. via Tech-talk
Next: RE: connection timeout between ioc and logstash Kivel Niko (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: Undefined Timestamp on Motor Record Torsten Bögershausen via Tech-talk
ANJ, 16 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
