1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: connection timeout between ioc and logstash
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Kivel Niko (PSI)" <[email protected]>
Date: Fri, 16 Aug 2019 09:27:39 -0500
On 08/16, Kivel Niko (PSI) wrote:
> Hi all
> while it's true that logstash (or whatever other logging facilities) could artificially keep the connection alive, it's only indirectly related to the actual problem. Which is, that the logger - while obviously noticing the broken connection - doesn't buffer and resend the failed message. It only sends the next message after the reconnect. Which might happen after another timeout.
> best
> Niko
That behavior wasn't clear to me in the original message.
Also, Xuan specifically asked the following:
> So how can keep the connection all the time without timeout. It seems
> that using iocLogServer will not lose connection.
Lewis
Re: Re: connection timeout between ioc and logstash 吴煊 via Tech-talk
Re: connection timeout between ioc and logstash J. Lewis Muir via Tech-talk
RE: connection timeout between ioc and logstash Kivel Niko (PSI) via Tech-talk
Prev: RE: Undefined Timestamp on Motor Record Dominic Oram - UKRI STFC via Tech-talk
Next: Re: Re: connection timeout between ioc and logstash 吴煊 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: connection timeout between ioc and logstash Kivel Niko (PSI) via Tech-talk
ANJ, 16 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
