1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: NDStats plugin shows huge numbers for Eiger detector (areaDetector 3.7)
From: "Sobhani, Bayan via Tech-talk" <[email protected]>
Date: Tue, 20 Aug 2019 13:48:54 +0000
I have an IOC running for an Eiger detector. The pixels are measured from -1.0 to 0.0. I think at least part of areaDetector recognizes this because when I set the Minimum and Maximum under “Display Controls” on the CSS screens, the picture looks good.
However, on the NDStats page, I see the minimum is 0, and the Maximum is 65535. I would expect the minimum to be -1.0, and the maximum to be 0. The Total is also a very large number (16407209312) – it was a much smaller number when I was running an older version of Areadetector (I think 2.7).
I thought the problem might be the Datatype – the DataType in the Stats plugin is UInt16. I attempted to change this to Float32 by writing to the Stats1:DataType PV, but it keeps reverting back to UInt16.
Any ideas what could be causing the numbers in the Stats1 plugin to be these huge numbers?
Alex
RE: NDStats plugin shows huge numbers for Eiger detector (areaDetector 3.7) Mark Rivers via Tech-talk
Prev: autosave - different PV to read and write Ryan Pierce via Tech-talk
Next: RE: NDStats plugin shows huge numbers for Eiger detector (areaDetector 3.7) Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: autosave - different PV to read and write Mark Rivers via Tech-talk
ANJ, 20 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
