1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Is anyone building AreaDetector with Sumo?
From: Jeong Han Lee via Tech-talk <[email protected]>
To: "Ivashkevych, Oksana" <[email protected]>
Date: Thu, 22 Aug 2019 22:04:42 +0200
Hi Oksana,
  	> BTW, how Debian-based facilities does handle the areadetector?
At NSLS2 we build from source, following areaDetectror build infrastructure.
All other modules we deploy via packages.
I only see https://github.com/epicsdeb/areadetector, however it is a quite old. Can you share the deb repository? I am really interesting to see how it works.
  Best,
  Han
-----Original Message-----
Behalf Of Jeong Han Lee via Tech-talk
Sent: Wednesday, August 21, 2019 6:55 PM
To: Johnson, Andrew N. <[email protected]>; EPICS tech-talk <tech-
[email protected]>
Hi Andrew,
On 8/21/19 8:14 PM, Johnson, Andrew N. via Tech-talk wrote:
I realise there probably aren't many sites out there using the HZB
Sumo package
<https://urldefense.proofpoint.com/v2/url?u=https-3A__goetzpf.bitbucke
t.io_sumo_&d=DwIDaQ&c=aTOVZmpUfPKZuaG9NO7J7Mh6imZbfhL47t9CpZ-
pCOw&r=x06s-qkiWY_RW6xat452vA&m=5vG3w0_2-
8knIdSfwVVSm2gDEe4AoiYEOu29dDnEHrQ&s=TJNyOGW4Nb6xD-N1PAEM-
vEkldFy8M6hcdcIVNAuYe8&e= >, but has anyone who does use it worked
out how to configure and build AreaDetector with it, either as a series of
separate modules or as one big module?
Unlike most EPICS modules AreaDetector has multiple kinds of RELEASE
files that need to be populated, and a non-trivial configuration
process (which is well-documented
3A__areadetector.github.io_master_install-
5Fguide.html&d=DwIDaQ&c=aTOVZmpUfPKZuaG9NO7J7Mh6imZbfhL47t9Cp
Z-pCOw&r=x06s-qkiWY_RW6xat452vA&m=5vG3w0_2-
8knIdSfwVVSm2gDEe4AoiYEOu29dDnEHrQ&s=_O2G_8bHNjJhozoYHWIZ9ZD
4zbLNsGkLL3Q0beFus3I&e= >).
The Sumo tool automates the configuration and building of sets of
EPICS modules on demand, but I'm not sure if it can cope with
configuring AreaDetector. If someone has succeeded in doing so I would
be grateful to hear details or ideas how best to approach it — I
haven't tried yet and I will need to do that soon.
     If the Sumo tool does its job well with the most EPICS modules, I think,
the tool does the same job on the AreaDetector also. But we may not use
the current global configuration files of areadetector with the Sumo tool,
because here we (ESS) can build them as individual modules, and combine
"necessary components" to build "an Application" and run an IOC without
any issues.
     For example, in order to see images from a PointGrey  (FLIR) camera,
     Here (ESS), we define system libraries and ADSupport clearly in terms of
OS. And we compile ADSupport as a module, And we compile ADCore which
has the maximum configuration options with both dependent libraries
(system and ADSupport) together. And we compile ADPointGrey according
to ADCore, ADSupport, and system libraries. (Note that the vendor libraries
also we have to consider.)
     The full dependent chain for my example (ignore system libraries and
vendor lib) is
     EPICS Base < Asyn < ADsupport < ADCore < ADPointGrey < FLIR Camera IOC
application
     In addition, you also have to consider how you would like to handle all
template files and configuration files in the different manners.
     HTH,
     Han
- Andrew
Complexity comes for free, Simplicity you have to work for.
RE: Is anyone building AreaDetector with Sumo? Ivashkevych, Oksana via Tech-talk
Is anyone building AreaDetector with Sumo? Johnson, Andrew N. via Tech-talk
Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
Prev: RE: Is anyone building AreaDetector with Sumo? Ivashkevych, Oksana via Tech-talk
Next: RE: Is anyone building AreaDetector with Sumo? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: RE: Is anyone building AreaDetector with Sumo? Ivashkevych, Oksana via Tech-talk
ANJ, 22 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
