the discussion about sumo triggered me to take a look at this tool to figure
out if it can helm me to solve a problem I currently have. I need to setup a
procedure to roll out a set of EPICS modules for a project that will be
installed also off site by inexperienced persons. And looking at the
documentation sumo would exactly do what I need. I would configure my IOC
application using sumo and the locally installed modules. Then I would roll
out the application together with the sumo config files and it would be a few
well documented steps to get the IOC compiled an running.
Currently I have a set of shell scripts, a set of patches for the
configuration files and a Makefile to do the job. But as the configuration
files change with every new release, I need to create the patches on a regular
basis. That step I would like to get rid off.
So I installed all EPICS modules I need, together with base in the directory
structure needed by sumo (modules/src/<module name>/<module version>).
Then I ran sumo-scan on the modules directory to get the configuration. All my
modules where clonedout from github and the latest tag was checked out. Much
to my surprise sumo-scan put all modules as "path" type, only areaDetector sub
modules (besides aravisGigE) where detected as "git" repositories.
Looking with "sumo-scan -t" at what is done during the process, Isee a small
difference between the areaDetector and all other modules:
git -C .../modules/src/areaDetector/3-7/ADSupport status --porcelain
returns nothing, while e.g.
git -C .../modules/src/iocStats/3.1.15 status --porcelain
returns
M configure/RELEASE
Which I needed to change to be able to define all the depended modules.
So here I#m stuck. Do I realy have to create the dependency file by hand?
Any tips and ideas welcome!
Regards
Jörn Dreyer
- Re: Sumo test Mark Rivers via Tech-talk
Re: Is anyone building AreaDetector with Sumo? Jeong Han Lee via Tech-talk
<2019>
2025
2026
RE: CameraLink and ADPCO Mark Rivers via Tech-talk
<2019>
2025
2026
