1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: FW: Keysight B2987A electrometer
From: "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Wed, 28 Aug 2019 19:32:39 +0000
Sent: Wednesday, August 28, 2019 2:31 PM
To: Engbretson, Mark S. <[email protected]>
Subject: RE: Keysight B2987A electrometer
You are right.
We have a couple of IOCs we have created or adapted and they were submitted to the collaboration repository as well. Also, we keep them at
James R. Piton
[email protected]
+55 (19) 3512 1228
Grupo SOL-Software das Linhas de Luz / Beamline Software Group
Laboratório Nacional de Luz Síncrotron - LNLS
Centro Nacional de Pesquisa em Energia e Materiais - CNPEM
De: Engbretson, Mark S. <[email protected]>
Enviado: quarta-feira, 28 de agosto de 2019 16:13
Para: James Rezende Piton <[email protected]>
Assunto: RE: Keysight B2987A electrometer
So long as who every builds these things don’t have multi-line status replies that all have to be parsed out, or complex have-to-do-10-things-in-the-right-order state machine type commands, most of the time getting the minimal functionality out of these things is easy.
The bad part is the very few people are putting their protocol files in a common location so that people can more easily find and use them.
Sent: Wednesday, August 28, 2019 2:08 PM
Yes, I really found another of them, a multimeter, and that is close to the functions we need here.
TKS!
James R. Piton
[email protected]
+55 (19) 3512 1228
Enviado: quarta-feira, 28 de agosto de 2019 16:03
I think that there is one or 2 other keysight devices on github, they all using protocol files, which makes doing these *A LOT* easier than they used to be.
Sent: Wednesday, August 28, 2019 1:35 PM
Many thanks, Mark! I appreciate your help. That might be a good starting point, indeed.
Best regards,
James R. Piton
[email protected]
+55 (19) 3512 1228
Enviado: quarta-feira, 28 de agosto de 2019 15:16
Might a related protocol file from a different Keysight device help you do one for your own device?
https://github.com/epicsdeb/keysight-n5171b
From: [email protected] <[email protected]> On Behalf Of James Rezende Piton via Tech-talk
Sent: Wednesday, August 28, 2019 1:10 PM
To: [email protected]
Subject: Keysight B2987A electrometer
Does anyone have an IOC for the Keysight electrometer model B2987A that could be shared?
Thanks in advance!
James R. Piton
[email protected]
+55 (19) 3512 1228
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Keysight B2987A electrometer James Rezende Piton via Tech-talk
Prev: Keysight B2987A electrometer James Rezende Piton via Tech-talk
Next: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
