1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 29 Aug 2019 11:24:29 +0000
Following on the issue below. I forgot to provide more information:
The device is communicating with UDP. The socket is being initialized and open in the constructor. What I noticed is that no matter what, the asyn driver instance does not take the output record’s VAL field on IOC startup, it always take the last value written (which I don’t know where it is being fetched even if the input record) is not loaded.
I tried using setIntegerParam in the constructor but it did not work, I tried using callParamCallbacks the same way as a previous working asynPortDriver, I played with asyn flags (multi-device and can block), still on IOC startup the VAL value is not loaded. Communication-wise everything is working, I can read/write with no problem.
A workaround to this is to have separate parameters for set and get records and skip each one in the opposite asyn read/write functions. I don’t think this is a good solution in case of large number of parameters. But what I did notice is that each time the IOC starts, readInt32 gets called then writeInt32 then readInt32 again.
Best Regards,
Abdalla.
Sent: Wednesday, August 28, 2019 3:55 PM
To: [email protected]
Subject: Force AsynPortDriver to write an output record's value to the device instead of fetching it
Hi
We have output records that uses asynPortDriver-based driver, they all have an initial value on IOC startup through the VAL field and PINI is set to YES. Instead of this value being set to the device on startup, they somehow contain the last value being set. It seems that it is discarding the record’s VAL field, even if the input record is not loaded. Is there a way to make it write the record’s value at startup instead of the last set value? What am I missing here?
Best Regards,
Abdalla.
RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Mark Rivers via Tech-talk
Prev: FW: Keysight B2987A electrometer Engbretson, Mark S. via Tech-talk
Next: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 29 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
