1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it
To: 'Abdalla Ahmad' <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 29 Aug 2019 15:15:49 +0000
Hi Abdalla,
Ø  What I noticed is that no matter what, the asyn driver instance does not take the output record’s VAL field on IOC startup, it always take the last value written (which I don’t know where it is being fetched even if the input record) is not loaded.
The behavior you describe is intentional.  It is designed to support “bumpless reboots” where output records can be initialized to the current hardware values.
This is documented in the asyn driver documentation https://epics.anl.gov/modules/soft/asyn/R4-36/asynDriver.html#DeviceInitialValues which says this:
Initial values of output records
The device support for output records on register based interfaces (bo, mbbo, ao, longout) does an initial read() of the value from the driver in init_record. If this read() returns asynSuccess then the record value is set to the value returned from read(). If read() returns anything other than asynSuccess then the record value is not modified. This mechanism supports "bumpless reboots" where the initial value of output records will match the current value of the hardware when the IOC starts. Drivers should only return asynSuccess from the read() function if the value is known to be valid. Note that this value read from the device will replace the value in the database when iocInit begins. However, the value read from the device may in turn be replaced by any value from save/restore, because the auto restore happens later in iocInit.
Beginning in R4-30 devAsynOctet was changed to also support the initial readback for stringout and waveform output records. The initial readback is only done if the record in the database contains the following line:
info(asyn:INITIAL_READBACK, "1")
This tech-talk thread also discussed the issue https://epics.anl.gov/tech-talk/2016/msg00963.php.  It says:
Where does an output record (ao, longout, mbbo, etc.) get its initial value?
  1. From the aoRecord.dbd file
  2. From the database file you load
  3. asyn device support init_record function does a read from your asyn driver to read the current value.
–     If your driver returns asynSuccess on that read then that value is used.
–     Supports bumpless reboots.
–     If using asynPort driver then if your driver has done setIntegerParam, setDoubleParam, or setStringParam before init_record (i.e. typically in constructor) then the readInt32, etc. functions will return asynSuccess.  If setInt32Param has not been done then readInt32 returns asynError, and that value will not be used.
  1. From save/restore
  2. dbpf at the end of startup script.
If you don’t want the output record to use the value read from the hardware then you have 3 choices:
-          Change the driver so that readInt32 returns asynError if it is called during iocInit
-          Use autosave, which will replace the value read from the hardware with the autosaved value
-          Call dbpf at the end of your startup script to write the desired value to the record.
Sent: Thursday, August 29, 2019 6:24 AM
To: [email protected]; Mark Rivers <[email protected]>
Following on the issue below. I forgot to provide more information:
The device is communicating with UDP. The socket is being initialized and open in the constructor. What I noticed is that no matter what, the asyn driver instance does not take the output record’s VAL field on IOC startup, it always take the last value written (which I don’t know where it is being fetched even if the input record) is not loaded.
I tried using setIntegerParam in the constructor but it did not work, I tried using callParamCallbacks the same way as a previous working asynPortDriver, I played with asyn flags (multi-device and can block), still on IOC startup the VAL value is not loaded. Communication-wise everything is working, I can read/write with no problem.
A workaround to this is to have separate parameters for set and get records and skip each one in the opposite asyn read/write functions. I don’t think this is a good solution in case of large number of parameters. But what I did notice is that each time the IOC starts, readInt32 gets called then writeInt32 then readInt32 again.
Best Regards,
Abdalla.
Sent: Wednesday, August 28, 2019 3:55 PM
Subject: Force AsynPortDriver to write an output record's value to the device instead of fetching it
Hi
We have output records that uses asynPortDriver-based driver, they all have an initial value on IOC startup through the VAL field and PINI is set to YES. Instead of this value being set to the device on startup, they somehow contain the last value being set. It seems that it is discarding the record’s VAL field, even if the input record is not loaded. Is there a way to make it write the record’s value at startup instead of the last set value? What am I missing here?
Best Regards,
Abdalla.
RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Abdalla Ahmad via Tech-talk
Prev: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Abdalla Ahmad via Tech-talk
Next: Cross compiling Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: RE: Force AsynPortDriver to write an output record's value to the device instead of fetching it Abdalla Ahmad via Tech-talk
ANJ, 01 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
