1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector NDPluginTimeSeries errors
To: "'Miceli, Antonino'" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Piatak, Christopher" <[email protected]>
Date: Thu, 29 Aug 2019 21:29:06 +0000
Hi Nino,
Ø  2019/08/29 13:18:56.594 asynPortDriver:drvUserCreate: addr=0, cannot find parameter TS_READ
Ø  dp_prosilica_xrd86:image1:TSRead devAsynInt32::initCommon drvUserCreate
This first set of errors is coming because your dbLoadRecords for NDTimeSeries.template has PORT=PS1 (the camera itself) rather than TS (the time series plugin you just created).  That database needs to be talking to a time-series plugin.
Can you explain what this NDPluginTimeSeries will be used for?  Generally that is used for time-series of scaler values, not images.
Ø  devAsynFloat64Array::initCommon, dp_prosilica_xrd86:Attr1:1:TSArrayValue connectDevice failed asynManager:connectDevice port ATTR1_TS not found
This second set of errors is coming because you are missing these lines after loading the NDAttributeN.template files:
NDTimeSeriesConfigure("ATTR1_TS", $(QSIZE), 0, "ATTR1", 1, 8)
dbLoadRecords("$(ADCORE)/db/NDTimeSeries.template",  "P=$(PREFIX),R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=$(NCHANS),ENABLED=1")
Those lines were added to EXAMPLE_commonPlugins.cmd in ADCore R3-5.
From: [email protected] <[email protected]> On Behalf Of Miceli, Antonino via Tech-talk
Sent: Thursday, August 29, 2019 4:00 PM
To: [email protected]
Cc: Piatak, Christopher <[email protected]>
Subject: areaDetector NDPluginTimeSeries errors
We have errors loading the NDPluginTimeSeries. Attached is the entire boot up of the st.cmd file.
Errors don't occur immediately when NDTimeSeriesConfigure or the dbLoadRecords but towards the end when autosave is loaded.
NDTimeSeriesConfigure("TS", 100, 0, "PS1", 0, 8, 0, 0, 0, 0)
dbLoadRecords("/local/DPbin/epics/epics_2019-06-26/support-R6-0/synApps/support/areaDetector-R3-6/ADCore-R3-6/db/NDTimeSeries.template","P=dp_prosilica_xrd86:,R=image1:,PORT=PS1, QSIZE=20,NCHANS=2048,CBUFFS=500,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PS1,NDARRAY_ADDR=0")
2019/08/29 13:18:56.598 asynPortDriver:drvUserCreate: addr=0, cannot find parameter TS_ACQUIRE_MODE
dp_prosilica_xrd86:image1:TSAcquireMode_RBV devAsynInt32::initCommon drvUserCreate
2019/08/29 13:18:56.599 asynPortDriver:drvUserCreate: addr=0, cannot find parameter TS_ACQUIRE
dp_prosilica_xrd86:image1:TSAcquire devBusyAsyn::initCommon drvUserCreate
2019/08/29 13:18:56.600 asynPortDriver:drvUserCreate: addr=0, cannot find parameter TS_ACQUIRE_MODE
dp_prosilica_xrd86:image1:TSAcquireMode devAsynInt32::initCommon drvUserCreate
2019/08/29 13:18:56.602 asynPortDriver:drvUserCreate: addr=0, cannot find parameter TS_TIME_PER_POINT
dp_prosilica_xrd86:image1:TSTimePerPoint devAsynFloat64::initCommon drvUserCreate
Error (514,514) PV: dp_prosilica_xrd86:image1:TSTimePerPoint ao: init_record
etc ...
devAsynFloat64Array::initCommon, dp_prosilica_xrd86:image1:TSTimeAxis drvUserCreate failed
devAsynFloat64Array::initCommon, dp_prosilica_xrd86:Attr1:2:TSArrayValue connectDevice failed asynManager:connectDevice port ATTR1_TS not found
devAsynFloat64Array::initCommon, dp_prosilica_xrd86:Attr1:3:TSArrayValue connectDevice failed asynManager:connectDevice port ATTR1_TS not found
devAsynFloat64Array::initCommon, dp_prosilica_xrd86:Attr1:4:TSArrayValue connectDevice failed asynManager:connectDevice port ATTR1_TS not found
etc ...
Any hints?
Nino
areaDetector NDPluginTimeSeries errors Miceli, Antonino via Tech-talk
Prev: areaDetector NDPluginTimeSeries errors Miceli, Antonino via Tech-talk
Next: Re: Sumo test Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: areaDetector-R3-3-1/ADCore compile error Ha, Kiman via Tech-talk
ANJ, 01 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
