1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector-R3-3-1/ADCore compile error
From: "Ha, Kiman via Tech-talk" <[email protected]>
Date: Sun, 1 Sep 2019 22:11:28 +0000
Hi Mark,
I am trying to compile an areaDetector-R3-3-1/ADCore but I found compile error “Magick++.h: No such file or directory”
I installed ImageMagick-6 module but I have no idea how to add Lib path.
/usr/local/include/ImageMagick-6 $ ls
magick  Magick++  Magick++.h  wand
   -MM -MF NDFileMagick.d  ../NDFileMagick.cpp
In file included from ../NDFileMagick.cpp:23:0:
../NDFileMagick.h:12:22: fatal error: Magick++.h: No such file or directory
compilation terminated.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPREFIX_MAGICK_SYMBOLS -DH5_NO_DEPRECATED_SYMBOLS -DH5Gopen_vers=2  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/asyn-R4-33/include     -I/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADSupport/include/os/Linux -I/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADSupport/include   -I/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADCore/include -I/home/bpmlab2/xilinx/epics/base-3.15.6/include/compiler/gcc -I/home/bpmlab2/xilinx/epics/base-3.15.6/include/os/Linux -I/home/bpmlab2/xilinx/epics/base-3.15.6/include        -c ../NDFileMagick.cpp
/home/bpmlab2/xilinx/epics/base-3.15.6/configure/RULES_BUILD:239: recipe for target 'NDFileMagick.o' failed
make[3]: *** [NDFileMagick.o] Error 1
make[3]: Leaving directory '/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADCore/ADApp/pluginSrc/O.linux-x86_64'
/home/bpmlab2/xilinx/epics/base-3.15.6/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADCore/ADApp/pluginSrc'
/home/bpmlab2/xilinx/epics/base-3.15.6/configure/RULES_DIRS:84: recipe for target 'pluginSrc.install' failed
make[1]: *** [pluginSrc.install] Error 2
make[1]: Leaving directory '/home/bpmlab2/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADCore/ADApp'
/home/bpmlab2/xilinx/epics/base-3.15.6/configure/RULES_DIRS:84: recipe for target 'ADApp.install' failed
make: *** [ADApp.install] Error 2
bpmlab2 ~/xilinx/epics/modules/synApps_6_0/support/areaDetector-R3-3-1/ADCore $
Kiman
Re: areaDetector-R3-3-1/ADCore compile error Mark Rivers via Tech-talk
Prev: Re: Force AsynPortDriver to write an output record's value to the device instead of fetching it Mark Rivers via Tech-talk
Next: Re: areaDetector-R3-3-1/ADCore compile error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector NDPluginTimeSeries errors Mark Rivers via Tech-talk
ANJ, 01 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
