1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 'isegHAL' module
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Bruno Martins <[email protected]>
Date: Mon, 2 Sep 2019 08:18:17 +0200
Hey Bruno,
last week we got two new MPOD crates with iseg CC24 and I tested the remote access.
There are no changes to the devIsegHal code necessary. We just need to link against a different library and include a different header file from the isegHAL. Username and Passwort for the remote access can be configured from the webinterface of the CC24. I recommend to disable the iseg-ioc on the CC24 if you want to use a remote IOC (also done via the webinterface)
Now I can use my IOC on my Debian 10 PC (x86_64) to control the HV and LV modules in my MPOD directly. I will ask iseg, if it's ok to send you the shared lib and header files.
Cheers,
Florian
On 8/23/19 7:30 PM, Bruno Martins wrote:
Hi Florian,
Thanks for letting me know! That looks promising indeed.
Bruno
On Fri, Aug 23, 2019 at 11:12 AM Florian Feldbauer <[email protected]> wrote:
Hey Bruno,
at least in the current master branch from isegHAL, I found the following in the readme:
Remote Access
The library isegHAL-service allows accessing isegHAL running on a computer
or iseg Crate somewhere in the local network or in the internet.
Secure sockets are used to crypt the communication between the two end points.
The API is completely the same as for isegHAL, with some adjustments and some
extensions, which are described here.
iseg_connect
The iseg_connect API call takes a special URL to connect to a remote server.
Example: iseg_connect("myEth", "hal://192.168.16.56:1454/can0,user,pass", NULL);
* The first parameter "myEth" is the session name, which must be unique for every
  client. A unique session name can be generated by the isegHAL API (see below).
* The second parameter "hal://192.168.16.56:1454/can0,user,pass" always starts
  with "hal://".
  Following, the remote hosts IP address or name, and, separated by a colon (:),
  the port are given. The remote server always uses port 1454, but it may be
  necessary to use an other port if the remote server is behind a network router.
  After the slash (/), further arguments are given: the used interface (can0),
  the login user name (user) and the password (pass).
* The third parameter is reserved at the moment and should always be NULL.
I'm not sure, if the the iseg-ioc currently supports this though. I will test it on Monday and maybe update the iseg-ioc accordingly.
By the way: the code of the device support package is now on github: https://github.com/ffeldbauer/devIsegHal.
Some additions from Bruce are merged there
Have a nice weekend!
Florian
On 8/9/19 4:52 PM, Bruno Martins wrote:
Hi Florian,
Thanks for the info, it makes more sense now. The cc24 manual mentions secure sockets (I assumed ssl), but maybe that's not available.
Maybe it would be possible to create a TCP bridge for this Unix socket so it can be exposed on a second machine.
Bruno
On Fri, Aug 9, 2019, 10:21 Florian Feldbauer via Tech-talk <[email protected]> wrote:
Hey,
since we have a very old crate from iseg, which does not have the cc24 controller, I'm running the isegHAL-Daemon and my isegIOC on a BeagleBone Black, which is connected via CAN bus to our HV modules.
But for crates with CC24 controller the isegHAL and the corresponding IOC have to run on that controller. IIRC the isegioc connects via a local unix-socket to the isegHAL. So, the IOC connecting to the HAL cannot run on a different PC...
Cheers,
Florian
On 8/9/19 3:50 PM, Bruno Martins via Tech-talk wrote:
Hi Bruce,
I am working with Ethan on this project. Our goal is similar to yours: to use our standard tools and link some extra EPICS modules with the iseg IOC. Is it not possible at all to have a client to this isegHALservice that runs elsewhere? I am assuming such client would be just exchanging messages like "get voltage", "get status", "set voltage", etc.
Thanks!
Bruno
On Fri, Aug 9, 2019 at 1:24 AM Hill, Bruce via Tech-talk <[email protected]> wrote:
Hi All,
The embedded IOC in these iSeg CC24 controllers is indeed the
fastest and easiest route to getting EPICS control of the modules.
If you only have a few crates you can hand customize and install
the iseg_epics.db and iseg_epics.sub files and you're good to go!
At SLAC we'll be deploying 6-10 of these mpod crates each w/ several
HV modules and may add some additional crates and/or LV modules
as we commission more LCLS2 chambers.
We wanted to be able to upgrade and version control our iSeg IOCs
w/ the same tools and EPICS 7 base releases as our other IOCs so we
found a way to do that and also add access security.
iSeg provided us w/ the arm-apalis gnu toolchain so we're cross-compiling
the iSegHAL module on our RHEL7 build server along w/ our EPICS base
and support modules and building IOC releases there on NFS.
The CC24 uses systemd services for startup, so we disable the isegioc
and install three slac systemd services.   One service does an NFS mount,
the next runs a startup script on the NFS mount that does other NFS
mounts, and a third that launches the IOC.
I've got this working on a demo unit and am looking forward to getting
our deployment crates and HV in so I can iron out any kinks in the scripts.
I"ve actually made a number of other changes to our demo system in the
course of this development so I need to make sure this all works from a
clean factory CC24.
If anyone's interested, contact me and I can provide more details re how
to get this working.
Cheers,
- Bruce
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
On 8/8/19 12:05 AM, laurent daudin via Tech-talk wrote:
Dear Ethan,
Why don't you use directly the CC24 embedded IOC ?
I am using the EPICS "isegHAL" which is already in the controler, so from the iCS controler WEB page in the EPICS section you just have to :
- download the "iseg_epics.db" and "iseg_epics.sub" files
- modify these files if needed
- Upload these new files
- reboot the EPICS IOC
and it should works !
regards,
Laurent.
Le 07/08/2019 à 22:47, Fulcher, Ethan via Tech-talk a écrit :
Hello all,
I am building an IOC for an iseg CC24 Master power supply, and need an EPICS module called 'isegHAL'. I wasn't able to find a download for it on the hardware support by manufacturer EPICS webpage (https://epics.anl.gov/modules/manufacturer.php#ISEG). Would anyone know about this module or where to get it?
Thank you,
Ethan Fulcher
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Email: [email protected]
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Re: EPICS 'isegHAL' module Bruno Martins via Tech-talk
EPICS 'isegHAL' module Fulcher, Ethan via Tech-talk
Re: EPICS 'isegHAL' module laurent daudin via Tech-talk
Re: EPICS 'isegHAL' module Hill, Bruce via Tech-talk
Re: EPICS 'isegHAL' module Florian Feldbauer via Tech-talk
Prev: RE: areaDetector-R3-3-1/ADCore compile error Ha, Kiman via Tech-talk
Next: Re: pvGet in Sequence does not work with incorrect size Simon Reiter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 'isegHAL' module Bruno Martins via Tech-talk
Next: Re: EPICS 'isegHAL' module Bruno Martins via Tech-talk
ANJ, 02 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
