Hi Sandeep, On Fri, Sep 6, 2019 at 4:46 AM Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]> wrote:
Oh, yes, I see that this module is making bad assumptions about what a PV name can be. This is at which currently reads: pv_name = Word(alphanums+":._$()") That would definitely need a '-' added. For now, you could just add that to the `epics/autosave/save_restore.py` file on your system to see if that fixes the problem. I believe this should also allow '{' and '}', but I'm not sure if there are other characters that should be allowed. Is there a published regex _expression_ for valid PV names? --Matt
| ANJ, 06 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
