Hi Matt,
At line no
https://github.com/pyepics/pyepics/blob/master/epics/autosave/save_restore.py#L184, adding “-“ was a quick fix and its working.
Cheers
Sandeep Malu
Sent: 06 September 2019 13:46
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Cc: [email protected]
Subject: Re: pyepics autosave
On Fri, Sep 6, 2019 at 4:46 AM Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]> wrote:
Oh, yes, I see that this module is making bad assumptions about what a PV name can be. This is at
pv_name = Word(alphanums+":._$()")
That would definitely need a '-' added. For now, you could just add that to the `epics/autosave/save_restore.py` file on your system to see if that fixes the problem.
I believe this should also allow '{' and '}', but I'm not sure if there are other characters that should be allowed.
Is there a published regex _expression_ for valid PV names?
- pyepics autosave Sandeep Kumar Malu - UKRI STFC via Tech-talk
- Re: pyepics autosave Matt Newville via Tech-talk
Re: pyepics autosave Mark Rivers via Tech-talk
Re: pyepics autosave Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
Re: pyepics autosave J. Lewis Muir via Tech-talk
use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
<2019>
2025
2026
ANJ, 09 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
