1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics autosave
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 6 Sep 2019 09:51:56 -0500
On 09/06, Johnson, Andrew N. via Tech-talk wrote:
> The AppDevGuide also says in section 6.4.11.2:
> > The record name. This must be composed out of only the following characters:
> > a-z A-Z 0-9 _ - + : [ ] < > ;
> Neither description includes the ‘{}’ characters that NSLS-2
> introduced into their record naming convention without realizing that
> they weren’t permitted according to the documentation. However IIRC
> the IOC code will actually accept any character string that doesn’t
> contain ‘.’ or space characters for a record name (I vaguely
> remember adding some checks to the parser, but that may have just been
> for dots and spaces).
If '{' and '}' are going to be allowed, then I hope they get added to
the Application Developer's Guide.
Lewis
pyepics autosave Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: pyepics autosave Matt Newville via Tech-talk
Re: pyepics autosave Mark Rivers via Tech-talk
Re: pyepics autosave Johnson, Andrew N. via Tech-talk
Prev: RE: pyepics autosave Engbretson, Mark S. via Tech-talk
Next: Re: Image display on ImageJ not showing up. [AravisGigE, areaDetector, ADViewer] Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: RE: pyepics autosave Sandeep Kumar Malu - UKRI STFC via Tech-talk
ANJ, 08 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
