1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics callback
From: Matt Newville via Tech-talk <[email protected]>
To: Alfio Rizzo <[email protected]>
Date: Mon, 9 Sep 2019 10:50:21 -0500
Hi Alfio,
On Mon, Sep 9, 2019 at 10:08 AM Alfio Rizzo via Tech-talk <[email protected]> wrote:
Hi
I made a simple python script to get the updated value of my PV
with a simple callback function :
import epics
import time
def onChanges(**kw):
    print ('PV Changed! ', kw["pvname"], kw["value"], kw["units"], time.ctime())
mypv = epics.PV("TCU6:RF")
mypv.add_callback(onChanges)
while True:
    pass
The issue is that the unit is shown as None even if it defined in the .db
PV Changed!  TCU6:RF -39.69 None Mon Sep  9 15:03:58 2019
PV Changed!  TCU6:RF -39.73 None Mon Sep  9 15:03:59 2019
PV Changed!  TCU6:RF -39.71 None Mon Sep  9 15:04:00 2019
PV Changed!  TCU6:RF -39.7 None Mon Sep  9 15:04:01 2019
PV Changed!  TCU6:RF -39.67 None Mon Sep  9 15:04:02 2019
But if I add this line on the script before to add the callback
mypv.units
Then when I restart the script it shows the unit correctly
PV Changed!  TCU6:RF -39.79 dBm Mon Sep  9 15:04:31 2019
PV Changed!  TCU6:RF -39.71 dBm Mon Sep  9 15:04:32 2019
PV Changed!  TCU6:RF -39.69 dBm Mon Sep  9 15:04:33 2019
Is this a bug/feature or I am doing something wrong ?
Hm, I think this is mostly a timing issue, but we could try to make this better.  Basically, in the first variation, the PV never asked for its CTRL fields, so it does not know what they are.  When you ask for the units (or any other CTRL fields), it goes and fetches all of them (once) and includes those in the monitor callback.
So doing
    mypv = epics.PV(pvname)
    mypv.get_ctrlvars()
    mypyv.add_callback(onChanges)
is probably the best way to get the units into your callback.
If you expect that the units might actually change, you should create the PV with `form='ctrl'` as Eric suggested.
Hope that helps,
--Matt
PNG image
pyepics callback Alfio Rizzo via Tech-talk
Prev: Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
Next: Driver for Smargon gniometer Randall Cayford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pyepics callback Eric Norum via Tech-talk
ANJ, 09 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
