1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: use CA Client in Xilinx MicroBlaze system
To: [email protected]
Date: Tue, 10 Sep 2019 12:09:35 +0800 (GMT+08:00)
thanks!
now my plan is:
- To build EPICS base3.15 on a linux PC
- using cross compiler to build for a linux-microblaze system,and then i can get the libCa.a , libCom.a and cadef.h files from the "<EPICS base>/lib/<architecture>", then i can use these files to write a CA client ued for microblaze-based linux system.
is that right?
my problem are:
- the EPICS base used in other system is R3.14, if i build R3.15 and use some libs to write a CA client, i don't know if there are incompatibility problems on communicating(specially when using ca_get or ca_put) with R3.14.
- in the CONFIG.Common.linux-microblaze file, it tell me to clone the cross compiler from github to my PC, and then set the GNU_DIR to point to the un-tarred tool-chain;however, the website in this file is no longer existing, so i can't find a proper cross compiler. sorry it is not a EPICS problem, maybe i should find the lasted cross compiler on google.
Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
use CA Client in Xilinx MicroBlaze system 肖麟阁 via Tech-talk
Prev: Re: Fwd: Re: Fwd: cross-compiling (kind of) with Buildroot Pierrick M Hanlet via Tech-talk
Next: RE: Driver for Smargon gniometer James.OHea--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
Next: Re: use CA Client in Xilinx MicroBlaze system Johnson, Andrew N. via Tech-talk
ANJ, 10 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
