1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: lcaGet maximum readout array size
To: "Ha, Kiman" <[email protected]>
Cc: "Podobedov, Boris" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Sep 2019 14:05:44 -0700
From the error message it sounds like the transfer time limit simply isn’t long enough to handle this much data.
I don’t think that there is an environment variable for setting the time limit.  The client source code might need to be changed.
On Sep 11, 2019, at 2:02 PM, Ha, Kiman via Tech-talk <[email protected]> wrote:
Yse, I did 5 Gbytes.
export EPICS_CA_MAX_ARRAY_BYTES=5000000000
Sent: Wednesday, September 11, 2019 4:55 PM
To: Ha, Kiman <[email protected]>; [email protected]
Cc: [email protected]; Podobedov, Boris <[email protected]>
Did you check/set the infamous EPICS_CA_MAX_ARRAY_BYTES?
On 9/11/19 1:20 PM, Ha, Kiman wrote:
Hi all,
I am trying to readout  (180 * 4 PVs) * 1 M point BPM ADC raw data using the lcalab.
But, I found errors at waveform size > (180*4*100K) point.
Any solutions for readout 180*4*1M array size?
% BPM [180x1]
tmp1=strcat(BPM, 'Ampl:ARaw-I');
tmp2=strcat(BPM, 'Ampl:BRaw-I');
tmp3=strcat(BPM, 'Ampl:CRaw-I');
tmp4=strcat(BPM, 'Ampl:DRaw-I');
Reading waveforms...
Error using lcaGet
multi_ezca_get -  ezcaGetWithStatus(): no response in time
Error in adcLongWfmRead_1m (line 276)
        allADC = lcaGet([tmp1; tmp2; tmp3; tmp4], WLength);
Kiman
Re: lcaGet maximum readout array size Mark Rivers via Tech-talk
lcaGet maximum readout array size Ha, Kiman via Tech-talk
Re: lcaGet maximum readout array size Till Straumann via Tech-talk
RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
Prev: RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
Next: Re: lcaGet maximum readout array size Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
