If the client is using ezca, which it sounds like it is, you can set both the timeout and the number of retries. I have run into this in the past with ezca which is used in the IDL CA library.
Sent from my iPhone
On Sep 11, 2019, at 4:05 PM, Eric Norum via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
From the error message it sounds like the transfer time limit simply isn't long enough to handle this much data.
I don't think that there is an environment variable for setting the time limit. The client source code might need to be changed.
On Sep 11, 2019, at 2:02 PM, Ha, Kiman via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Yse, I did 5 Gbytes.
export EPICS_CA_MAX_ARRAY_BYTES=5000000000
From: Till Straumann <[email protected]<mailto:[email protected]>>
Sent: Wednesday, September 11, 2019 4:55 PM
To: Ha, Kiman <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]>
Cc: [email protected]<mailto:[email protected]>; Podobedov, Boris <[email protected]<mailto:[email protected]>>
Subject: Re: lcaGet maximum readout array size
Did you check/set the infamous EPICS_CA_MAX_ARRAY_BYTES?
On 9/11/19 1:20 PM, Ha, Kiman wrote:
Hi all,
I am trying to readout (180 * 4 PVs) * 1 M point BPM ADC raw data using the lcalab.
But, I found errors at waveform size > (180*4*100K) point.
Any solutions for readout 180*4*1M array size?
% BPM [180x1]
tmp1=strcat(BPM, 'Ampl:ARaw-I');
tmp2=strcat(BPM, 'Ampl:BRaw-I');
tmp3=strcat(BPM, 'Ampl:CRaw-I');
tmp4=strcat(BPM, 'Ampl:DRaw-I');
Reading waveforms...
Error using lcaGet
multi_ezca_get - ezcaGetWithStatus(): no response in time
Error in adcLongWfmRead_1m (line 276)
allADC = lcaGet([tmp1; tmp2; tmp3; tmp4], WLength);
Kiman
- lcaGet maximum readout array size Ha, Kiman via Tech-talk
- Re: lcaGet maximum readout array size Till Straumann via Tech-talk
- RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
- Re: lcaGet maximum readout array size Eric Norum via Tech-talk
<2019>
2025
2026
Re: lcaGet maximum readout array size Mark Rivers via Tech-talk
<2019>
2025
2026
