1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: lcaGet maximum readout array size
To: "Ha, Kiman" <[email protected]>, Mark Rivers <[email protected]>
Cc: "Podobedov, Boris" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Sep 2019 21:41:48 +0000
Kiman:
Yes, the function is lcaSetTimeout, i.e. lcaSetTimeout(1.0) will set the timeout to 1 second. The default timeout is 0.1 second.
Other useful functions for your case:  lcaGetRetryCount, lcaSetRetryCount
BTW, you do not need to set EPICS_CA_MAX_ARRAY_BYTES to 5G.  A little bit greater than 1M*sizeof(data-type-of-ADC-raw-data) should be enough.
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Kiman Ha <[email protected]>
Date: Wednesday, September 11, 2019 at 5:12 PM
Subject: RE: lcaGet maximum readout array size
How to increase the timeout?
At the Matlab lcaLAB function or other ...?
Kiman
-----Original Message-----
Sent: Wednesday, September 11, 2019 4:56 PM
To: Ha, Kiman <[email protected]>
I think you need to increase the timeout or retries in ezca.
Sent from my iPhone
On Sep 11, 2019, at 3:20 PM, Ha, Kiman via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi all,
I am trying to readout  (180 * 4 PVs) * 1 M point BPM ADC raw data using the lcalab.
But, I found errors at waveform size > (180*4*100K) point.
Any solutions for readout 180*4*1M array size?
% BPM [180x1]
tmp1=strcat(BPM, 'Ampl:ARaw-I');
tmp2=strcat(BPM, 'Ampl:BRaw-I');
tmp3=strcat(BPM, 'Ampl:CRaw-I');
tmp4=strcat(BPM, 'Ampl:DRaw-I');
Reading waveforms...
Error using lcaGet
multi_ezca_get -  ezcaGetWithStatus(): no response in time
Error in adcLongWfmRead_1m (line 276)
        allADC = lcaGet([tmp1; tmp2; tmp3; tmp4], WLength);
Kiman
RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
Re: lcaGet maximum readout array size Mark Rivers via Tech-talk
Prev: Re: lcaGet maximum readout array size Sebek, Jim via Tech-talk
Next: RE: lcaGet maximum readout array size Ha, Kiman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 11 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
