And if I want to use
a PV defined in the database? What can I use?
Thank you
Pilar
On 12/9/19 15:17, Kasemir, Kay wrote:
I'm using a local PV, why is the value of the PV IVdouble ??
Is it possible to avoid this conversion??
Because local numeric PVs default to double, and local text PVs default to String.
If you want int or long, try "loc://my_pv<VInt>(0)" or "loc://my_pv<VLong>(0)"
-Kay
This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it. |
- Re: [EXTERNAL] CSS jython setvalue behaviour Kasemir, Kay via Tech-talk
- CSS jython setvalue behaviour Pilar via Tech-talk
- Re: [EXTERNAL] CSS jython setvalue behaviour Pilar Gil via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
ANJ, 12 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
