This is perplexing me. Trying to upgrade our EPICS distro from 3.14.12.8 to 3.15.6, but when it is compiling for our various RTEMS powerpc BSPs, the build fails with this:/gem_sw/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/mvme3100/lib/ -specs bsp_specs -qrtems -fasm -mcpu=powerpc -msoft-float -D__ppc_generic -DUNIX -O2 -g -g -Wall -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include -c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: error: bsp/bspExt.h: No such file or directory ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c: In function 'rtemsDevInit': ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:129: warning: implicit declaration of function 'bspExtInit' make[3]: *** [devLibVMEOSD.o] Error 1 make[3]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom/O.RTEMS-mvme3100' make[2]: *** [install.RTEMS-mvme3100] Error 2 make[2]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src' make: *** [src.install] Error 2 It can't find the header file for libbspExt in <bsp/bspExt.h>, even though it's right there where it's always been and can be found when compiling our previoous versions of EPICS... I've looked at all the files in .../base/configure, but I don't see what has changed that might cause this. Any pointers appreciated. -- Mike Westfall Control Systems Software Engineer
| ANJ, 13 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
