1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems compiling base-3.15.6 with RTEMS
From: Heinz Junkes via Tech-talk <[email protected]>
To: Michael Westfall <[email protected]>
Date: Fri, 13 Sep 2019 15:35:07 +0200
You have to provide rtems-libbspext
You can find the version I am using for RTEMS(5) here
https://cloud.fhi-berlin.mpg.de:8443/getlink/fiT4VCaiiftK4A7jj5oZeLY7/rtems-libbspext.tgz
Befor compilation, make sure that RTEMS_MAKEFILE_PATH is set and points to the used bsp. E.g
RTEMS_MAKEFILE_PATH=/Users/junkes/MVME2500/RTEMS/rtems-5/powerpc-rtems5/qoriq_e500
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 13. Sep 2019, at 13:55, Michael Westfall via Tech-talk <[email protected]> wrote:
> This is perplexing me.
> Trying to upgrade our EPICS distro from 3.14.12.8 to 3.15.6, but when it is compiling for our various RTEMS powerpc BSPs, the build fails with this:
> /gem_sw/targetOS/RTEMS/rtems-4.10/bin/powerpc-rtems4.10-gcc --pipe -B/gem_sw/targetOS/RTEMS/rtems-4.10/powerpc-rtems4.10/mvme3100/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=powerpc -msoft-float -D__ppc_generic                  -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL -DHAVE_MOTLOAD -DRTEMS_NETWORK_CONFIG_MBUF_SPACE=2048 -DRTEMS_NETWORK_CONFIG_CLUSTER_SPACE=5120     -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/RTEMS -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/RTEMS -I../../../include         -c ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c
> ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:26:24: error: bsp/bspExt.h: No such file or directory
> ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c: In function 'rtemsDevInit':
> ../../../src/libCom/osi/os/RTEMS/devLibVMEOSD.c:129: warning: implicit declaration of function 'bspExtInit'
> make[3]: *** [devLibVMEOSD.o] Error 1
> make[3]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom/O.RTEMS-mvme3100'
> make[2]: *** [install.RTEMS-mvme3100] Error 2
> make[2]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src/libCom'
> make[1]: *** [libCom.install] Error 2
> make[1]: Leaving directory `/gem_sw/epics/R3.15.6/epics-base/src'
> make: *** [src.install] Error 2
> It can't find the header file for libbspExt in <bsp/bspExt.h>, even though it's right there where it's always been and can be found when compiling our previoous versions of EPICS...
> I've looked at all the files in .../base/configure, but I don't see what has changed that might cause this.
> Any pointers appreciated.
> Mike Westfall
> Control Systems Software Engineer
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
Prev: Re: Problems compiling base-3.15.6 with RTEMS Ralph Lange via Tech-talk
Next: Re: Problems compiling base-3.15.6 with RTEMS Michael Westfall via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 13 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
