Dear
I am installing xxx-R6-1 module. The result is "make make -C ./configure install make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/configure' make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/configure/O.linux-x86_64' perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/configure/O.linux-x86_64' make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/configure' make -C ./xxxApp install make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp' make -C ./src install make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp/src' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[3]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp/src/O.linux-x86_64' Creating dbd file iocxxxLinux.dbd perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/dbdExpand.pl -I. -I.. -I../O.Common -I../../../dbd -I/home/epics0/Apps/epics/base/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/camac-R2-7-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/caputRecorder-R1-7-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/dac128V-R2-9/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/delaygen-R1-2-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/dxpSITORO-R1-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/ip-R2-20-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/ipac-2-15/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/ip330-R2-9/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/ipUnidig-R2-11/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/love-R3-2-7/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/lua-R2-0/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/measComp-R2-3/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/modbus-R3-0/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/motor-R7-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/optics-R2-13-3/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/quadEM-R9-2-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/softGlue-R2-8-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/softGlueZynq-R2-0-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/std-R3-6/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/StreamDevice-2-8-9/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/vac-R1-9/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/vme-R2-9-2/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/Yokogawa_DAS-R2-0-1/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/dbd -I/home/epics0/Apps/epics/synApps_6_1/support/allenBradley-2-3/dbd -o iocxxxLinux.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd qsrv.dbd NDPluginPva.dbd PVAServerRegister.dbd NDFileNetCDF.dbd NDFileMagick.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd aliveSupport.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd caputRecorder.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd drvVxi11.dbd devGpib.dbd stdSupport.dbd sscanProgressSupport.dbd opticsSupport.dbd mcaSupport.dbd drvAHxxx.dbd drvTetrAMM.dbd ipSupport.dbd luaSupport.dbd modbusSupport.dbd motorSupport.dbd devAcsMotor.dbd devAerotech.dbd devAttocube.dbd devFaulhaberMotor.dbd devImsMotor.dbd devKohzuMotor.dbd devMclennanMotor.dbd devMicos.dbd devMicroMo.dbd devNewFocus.dbd devNewport.dbd devAerotechSeq.dbd devNewportSeq.dbd devOriel.dbd devPC6K.dbd devPIJena.dbd devPIMotor.dbd devSPiiPlus.dbd devSmartMotorMotor.dbd devSoftMotor.dbd devThorLabs.dbd motorSimSupport.dbd stream.dbd devIocStats.dbd iocAdmin.dbd delaygenSupport.dbd vacSupport.dbd dxpSupport.dbd drvIpac.dbd ipUnidigSupport.dbd dac128VSupport.dbd ip330Support.dbd softGlueSupport.dbd softGlueZynqSupport.dbd mw100Support.dbd dbdExpand.pl: Can't find file 'dxpSupport.dbd' while reading 'dxpSupport.dbd' to create 'iocxxxLinux.dbd' Your Makefile may need this dependency rule: $(COMMON_DIR)/iocxxxLinux.dbd: $(COMMON_DIR)/dxpSupport.dbd dbdExpand.pl: Exiting due to errors /home/epics0/Apps/epics/base/configure/RULES.Db:403: recipe for target '../O.Common/iocxxxLinux.dbd' failed make[3]: *** [../O.Common/iocxxxLinux.dbd] Error 255 make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp/src/O.linux-x86_64' /home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp/src' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'src.install' failed make[1]: *** [src.install] Error 2 make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/xxx-R6-1/xxxApp' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'xxxApp.install' failed make: *** [xxxApp.install] Error 2 " Could you help me check where are errors from? Thanks Peiyu
| ANJ, 14 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
