1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Tech-talk Digest, Vol13, Issue381
To: 'peiyu Quan' <[email protected]>
Date: Fri, 13 Sep 2019 17:26:35 +0000
Hi Peiyu,
Ø  My first question is whether it can proved most of modules in areadetector have succeed in being installed, except simDetector?
You can look at /home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/lib/linux-x86_64 and you should see something like this:
corvette:measComp/measCompApp/src>ls -l ~/devel/areaDetector-3-7/ADCore/lib/linux-x86_64
total 32584
-r--r--r-- 1 epics domain users  2319668 Aug  8 13:59 libADBase.a
-r-xr-xr-x 1 epics domain users   958856 Aug  8 13:59 libADBase.so
-r--r--r-- 1 epics domain users  4155028 Aug  8 13:55 libADTestUtility.a
-r-xr-xr-x 1 epics domain users  1855264 Aug  8 13:55 libADTestUtility.so
-r--r--r-- 1 epics domain users 14679044 Aug  8 13:59 libNDPlugin.a
-r-xr-xr-x 1 epics domain users  6020976 Aug  8 13:59 libNDPlugin.so
-r--r--r-- 1 epics domain users  2262032 Aug  8 13:59 libntndArrayConverter.a
-r-xr-xr-x 1 epics domain users  1100568 Aug  8 13:59 libntndArrayConverter.so
Ø  My second question is how to solve this problem?
I have not seen those errors before, so I am not sure.  But I would suggest checking that the file
/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/configure/RELEASE_PRODS.local
looks correct for the locations of the packages on your system.
From: Tech-talk <[email protected]> On Behalf Of peiyu Quan via Tech-talk
Sent: Friday, September 13, 2019 11:51 AM
To: [email protected]
Subject: Tech-talk Digest, Vol13, Issue381
Dear
   I have installed most of modules in synApps before.
I am installing areadetector modules, It took about 20 mins, i didn't find any problem. But in finally,
It showed:
"/home/epics0/Apps/epics/base/configure/RULES_BUILD:191: recipe for target 'checkRelease' failed
make[5]: *** [checkRelease] Error 1
make[5]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
/home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[4]: *** [install.linux-x86_64] Error 2
make[4]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC/configure'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'configure.install' failed
make[3]: *** [configure.install] Error 2
make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs/simDetectorNoIOC'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'simDetectorNoIOC.install' failed
make[2]: *** [simDetectorNoIOC.install] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector/iocs'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'iocs.install' failed
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector'
/home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target '/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector.install' failed
make: *** [/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSimDetector.install] Error 2
Thanks
Peiyu
UW-Madsion
Prev: Tech-talk Digest, Vol13, Issue381 peiyu Quan via Tech-talk
Next: RE: Tech-talk Digest, Vol13, Issue381 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Tech-talk Digest, Vol13, Issue381 Mark Rivers via Tech-talk
Next: Tech-talk Digest, Vol 13, Issue 384 peiyu Quan via Tech-talk
ANJ, 14 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
