Dear
I am installing dxp-R6-0 It showsome errors. 1.In file included from ../md_linux.c:65:0: ../md_linux.h:144:10: fatal error: usb.h: No such file or directory#include "usb.h" 2. nclude/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xia_usb_linux.c ../xia_usb_linux.c:41:10: fatal error: usb.h: No such file or directory #include <usb.h> ^~~~~~~ compilation terminated. /home/epics0/Apps/epics/base/configure/RULES_BUILD:234: recipe for target 'xia_usb_linux.o' failed make[3]: *** [xia_usb_linux.o] Error 1 make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64' /home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'handelSrc.install' failed make[1]: *** [handelSrc.install] Error 2 make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'dxpApp.install' failed make: *** [dxpApp.install] Error 2 The process as following: epics0@ubuntu:~/Apps/epics/synApps_6_1/support/dxp-R6-0$ make make -C ./configure install make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure' perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure/O.linux-x86_64' perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure/O.linux-x86_64' make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/configure' make -C ./dxpApp install make[1]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp' make -C ./handelSrc install make[2]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc' perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[3]: Entering directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64' /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF md_linux.d ../md_linux.c In file included from ../md_linux.c:65:0: ../md_linux.h:144:10: fatal error: usb.h: No such file or directory #include "usb.h" ^~~~~~~ compilation terminated. /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xia_epp_linux.d ../xia_epp_linux.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xia_usb_linux.d ../xia_usb_linux.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xia_file.d ../xia_file.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xia_assert.d ../xia_assert.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_xerxes.d ../handel_xerxes.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_system.d ../handel_system.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_sort.d ../handel_sort.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_run_params.d ../handel_run_params.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_run_control.d ../handel_run_control.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_log.d ../handel_log.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_file.d ../handel_file.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_dyn_module.d ../handel_dyn_module.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_dyn_firmware.d ../handel_dyn_firmware.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_dyn_detector.d ../handel_dyn_detector.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_dyn_default.d ../handel_dyn_default.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_detchan.d ../handel_detchan.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel_dbg.d ../handel_dbg.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF psl.d ../psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF fdd.d ../fdd.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF handel.d ../handel.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF md_log.d ../md_log.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xerxes_io.d ../xerxes_io.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF xerxes.d ../xerxes.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF stj_psl.d ../stj_psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF stj.d ../stj.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF udxp_psl.d ../udxp_psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF udxp_common.d ../udxp_common.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF udxp.d ../udxp.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF mercury_psl.d ../mercury_psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF mercury.d ../mercury.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF saturn_psl.d ../saturn_psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF saturn.d ../saturn.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -MM -MF md_linux.d ../md_linux.c In file included from ../md_linux.c:65:0: ../md_linux.h:144:10: fatal error: usb.h: No such file or directory #include "usb.h" ^~~~~~~ compilation terminated. Installing generic include file ../../../include/xia_common.h mkdir ../../../include Installing generic include file ../../../include/xia_xerxes.h Installing generic include file ../../../include/xerxes_generic.h Installing generic include file ../../../include/xia_xerxes_structures.h Installing generic include file ../../../include/xerxes_structures.h Installing generic include file ../../../include/xerxesdef.h Installing generic include file ../../../include/handel.h Installing generic include file ../../../include/handel_constants.h Installing generic include file ../../../include/handeldef.h Installing generic include file ../../../include/handel_generic.h Installing generic include file ../../../include/md_generic.h Installing generic include file ../../../include/handel_errors.h /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../saturn.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../saturn_psl.c ../saturn_psl.c: In function ‘pslSetAcquisitionValues’: ../saturn_psl.c:5618:32: warning: ‘%u’ directive writing between 1 and 10 bytes into a region of size 6 [-Wformat-overflow=] sprintf(limit, "sca%u_lo", i); ^~ ../saturn_psl.c:5618:28: note: directive argument in the range [0, 2147483647] sprintf(limit, "sca%u_lo", i); ^~~~~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../saturn_psl.c:38: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 8 and 17 bytes into a destination of size 9 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ../saturn_psl.c:5634:32: warning: ‘%u’ directive writing between 1 and 10 bytes into a region of size 6 [-Wformat-overflow=] sprintf(limit, "sca%u_hi", i); ^~ ../saturn_psl.c:5634:28: note: directive argument in the range [0, 2147483647] sprintf(limit, "sca%u_hi", i); ^~~~~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../saturn_psl.c:38: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 8 and 17 bytes into a destination of size 9 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../mercury.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../mercury_psl.c ../mercury_psl.c: In function ‘psl__GetSCAData’: ../mercury_psl.c:6246:33: warning: ‘%lu’ directive writing between 1 and 20 bytes into a region of size between 0 and 10 [-Wformat-overflow=] sprintf(memory, "burst:%#lx:%lu", addr, (unsigned long)totalSCA); ^~~ ../mercury_psl.c:6246:21: note: using the range [0, 18446744073709551615] for directive argument sprintf(memory, "burst:%#lx:%lu", addr, (unsigned long)totalSCA); ^~~~~~~~~~~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../xia_handel.h:43, from ../mercury_psl.c:43: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 10 and 39 bytes into a destination of size 18 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../udxp.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../udxp_common.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../udxp_psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../stj.c ../stj.c: In function ‘dxp_load_symbols_from_file’: ../stj.c:740:57: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘long unsigned int’ [-Wformat=] sprintf(info_string, "Error allocating %d bytes for 'params->" ~^ %ld In file included from ../stj.c:43:0: ../stj.c: At top level: ../xia_stj.h:113:32: warning: ‘dxp_find_file’ declared ‘static’ but never defined [-Wunused-function] XERXES_STATIC FILE* XERXES_API dxp_find_file(const char *, const char *); ^~~~~~~~~~~~~ ../xia_stj.h:115:30: warning: ‘dxp_do_cmd’ declared ‘static’ but never defined [-Wunused-function] XERXES_STATIC int XERXES_API dxp_do_cmd(int modChan, Board *board, byte_t cmd, unsigned int lenS, ^~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../stj_psl.c ../stj_psl.c:89:16: warning: ‘psl__UpdateParams’ declared ‘static’ but never defined [-Wunused-function] PSL_STATIC int psl__UpdateParams(int detChan, unsigned short type, int modChan, ^~~~~~~~~~~~~~~~~ ../stj_psl.c: In function ‘psl__SetBiasDacEnable’: ../stj_psl.c:8228:34: warning: ‘CHANENA’ directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=] sprintf(BANKnDSPNAME, "BANK%dCHANENA", bank); ^~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../xia_handel.h:43, from ../stj_psl.c:45: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 13 and 22 bytes into a destination of size 20 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ../stj_psl.c: In function ‘psl__SetTThresh’: ../stj_psl.c:2004:34: warning: ‘ADCGAIN’ directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=] sprintf(BANKnDSPNAME, "BANK%dADCGAIN", bank); ^~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../xia_handel.h:43, from ../stj_psl.c:45: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 13 and 22 bytes into a destination of size 20 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ../stj_psl.c: In function ‘psl__SetEThresh’: ../stj_psl.c:2104:34: warning: ‘ADCGAIN’ directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=] sprintf(BANKnDSPNAME, "BANK%dADCGAIN", bank); ^~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../xia_handel.h:43, from ../stj_psl.c:45: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 13 and 22 bytes into a destination of size 20 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ../stj_psl.c: In function ‘psl__UpdateGain’: ../stj_psl.c:2365:34: warning: ‘ADCGAIN’ directive writing 7 bytes into a region of size between 6 and 15 [-Wformat-overflow=] sprintf(BANKnDSPNAME, "BANK%dADCGAIN", bank); ^~~~~~~ In file included from /usr/include/stdio.h:862:0, from ../xia_handel.h:43, from ../stj_psl.c:45: /usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 13 and 22 bytes into a destination of size 20 return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ __bos (__s), __fmt, __va_arg_pack ()); ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xerxes.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xerxes_io.c ../xerxes_io.c:57:13: warning: ‘INFO_STRING’ defined but not used [-Wunused-variable] static char INFO_STRING[INFO_LEN]; ^~~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../md_log.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../fdd.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../psl.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_dbg.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_detchan.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_dyn_default.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_dyn_detector.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_dyn_firmware.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_dyn_module.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_file.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_log.c In file included from ../handel_log.c:42:0: ../handel_log.h:55:13: warning: ‘info_string’ defined but not used [-Wunused-variable] static char info_string[400]; ^~~~~~~~~~~ /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_run_control.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_run_params.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_sort.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_system.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../handel_xerxes.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xia_assert.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xia_file.c /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DEXCLUDE_XUP -DEXCLUDE_SERIAL -DEXCLUDE_VEGA -DEXCLUDE_UDXPS -DEXCLUDE_XMAP -DEXCLUDE_PLX -DLINUX -Wno-unused-but-set-variable -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/epics0/Apps/epics/synApps_6_1/support/seq-2-2-6/include -I/home/epics0/Apps/epics/synApps_6_1/support/asyn-R4-36/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADSupport/include -I/home/epics0/Apps/epics/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/autosave-R5-10/include -I/home/epics0/Apps/epics/synApps_6_1/support/busy-R1-7-2/include -I/home/epics0/Apps/epics/synApps_6_1/support/calc-R3-7-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/sscan-R2-11-3/include -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/iocStats-3-1-16/include -I/home/epics0/Apps/epics/synApps_6_1/support/alive-R1-1-1/include -I/home/epics0/Apps/epics/base/include/compiler/gcc -I/home/epics0/Apps/epics/base/include/os/Linux -I/home/epics0/Apps/epics/base/include -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include/os/Linux -I/home/epics0/Apps/epics/synApps_6_1/support/mca-R7-8/include -I/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/include -c ../xia_usb_linux.c ../xia_usb_linux.c:41:10: fatal error: usb.h: No such file or directory #include <usb.h> ^~~~~~~ compilation terminated. /home/epics0/Apps/epics/base/configure/RULES_BUILD:234: recipe for target 'xia_usb_linux.o' failed make[3]: *** [xia_usb_linux.o] Error 1 make[3]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc/O.linux-x86_64' /home/epics0/Apps/epics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp/handelSrc' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'handelSrc.install' failed make[1]: *** [handelSrc.install] Error 2 make[1]: Leaving directory '/home/epics0/Apps/epics/synApps_6_1/support/dxp-R6-0/dxpApp' /home/epics0/Apps/epics/base/configure/RULES_DIRS:84: recipe for target 'dxpApp.install' failed make: *** [dxpApp.install] Error 2 Thanks Peiyu
| ANJ, 15 Sep 2019 |
Home
News
About
Talk
Base
Modules
Extensions
