1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: New releases of the measComp module
To: tech-talk <[email protected]>
Date: Sat, 14 Sep 2019 19:59:29 +0000
Folks,
Releases 2-3 and 2-4 of the measComp module are now available.
R2-4 provides Linux support for the USB-CTR08.  This is an 8-channel counter/timer module.  It provides EPICS support for the scaler record, so it can be used as a replacement for the Joerger VSC8/16 and the SIS3820 modules that are no longer available.  It also provides support for the Multi-Channel Scaler mode of the SIS3820 for on-the-fly counting.  In addition it has 4 programmable pulse generators and 8 digital I/O lines.  The cost is only $470.
This is from the R2-4 release notes:
- Improvements to USB-CTR04/08 support
  - Added support for Linux.
  - Added Dwell_RBV record to show the actual dwell time which can be different from requested.
 - Added Point0Action record to control how the first time point in an MCS scan is handled. Choices are "Clear", "No clear", and "Skip".
  - Fixed bugs when FirstCounter!=0 or LastCounter!=7.
 - Fixed initialization bug which was causing random crashes at startup.
  - Improved update rate at long dwell times
This is from the R2-3 release notes:
- Improved behavior for E-1608 when there are brief network outages. If the waveform digitizer was running when the outage occurred it would stop and not restart when the network recovered. This has been fixed, and tested with the E-1608 on both Linux and Windows.
- Added Makefile to produce autoconverted OPI files from medm to edm, CSS/BOY, and caQtDM. Added/updated the autoconverted files for these.
The home page for measComp is here:
http://cars.uchicago.edu/software/epics/measComp.html
The documentation is here:
http://cars.uchicago.edu/software/epics/measCompDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/measCompReleaseNotes.html
The source repository is on Github:
https://github.com/epics-modules/measComp
Cheers,
Prev: Re: Tech-talk Digest, Vol 13, Issue 384 Mark Rivers via Tech-talk
Next: Tech-talk Digest, Vol13, Issue386 peiyu Quan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 15 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
