Hej all,
The warning(s) are actually fixed here:
<https://github.com/epics-modules/motor/pull/128/commits/13a8649abbb80c884d55169aa99647c76bb4b04d>
So I hope that someone finds time to merge/apply
those fixes into the code base.
On 18/09/19 16:44, Sintschuk, Michael wrote:
Thanks Torsten, this helped with the ATHM field which is 0 now. So the MSTA bits are now 2338 that corresponds to this status.
After commenting out the line "status.Bits.RA_HOME = status.Bits.RA_DONE;" in "drvPIE816.cc" i recompiled the motor-module and encountered this problem:
make[3]: Entering directory '/soft/epics/modules/motor-R6-10-1/motorApp/PiSrc/O.linux-x86_64'
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/../modules/asyn/include -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include -MM -MF drvPIE816.d ../drvPIE816.cc
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/local/epics/base/../modules/asyn/include -I/usr/local/epics/base/include/compiler/gcc -I/usr/local/epics/base/include/os/Linux -I/usr/local/epics/base/include -c ../drvPIE816.cc
../drvPIE816.cc:94:39: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
"K","L"};
../drvPIE816.cc: In function ‘int set_status(int, int)’:
../drvPIE816.cc:233:25: warning: variable ‘mr’ set but not used [-Wunused-but-set-variable]
struct motorRecord *mr;
../drvPIE816.cc:237:66: warning: unused variable ‘online_status’ [-Wunused-variable]
unsigned int overflow_status, ontarget_status, servo_status, online_status;
../drvPIE816.cc: In function ‘int motor_init()’:
../drvPIE816.cc:584:10: warning: unused variable ‘retry’ [-Wunused-variable]
int retry = 0;
/usr/bin/ar -rc libPI.a devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE517.o drvPIE517.o PIE517Register.o devPIE816.o drvPIE816.o PIE816Register.o
/usr/bin/ranlib libPI.a
/usr/bin/g++ -o libPI.so -shared -fPIC -Wl,-hlibPI.so -L/soft/epics/modules/motor-R6-10-1/lib/linux-x86_64 -L/soft/epics/modules/asyn4-32/lib/linux-x86_64 -L/soft/epics/base-3.15.5/lib/linux-x86_64 -Wl,-rpath,/soft/epics/modules/motor-R6-10-1/lib/linux-x86_64 -Wl,-rpath,/soft/epics/modules/asyn4-32/lib/linux-x86_64 -Wl,-rpath,/soft/epics/base-3.15.5/lib/linux-x86_64 -rdynamic -m64 devPIC844.o drvPIC844.o PiRegister.o devPIC630.o drvPIC630.o PIC630Register.o devPIC848.o drvPIC848.o PIC848Register.o devPIC662.o drvPIC662.o PIC662Register.o devPIC862.o drvPIC862.o PIC862Register.o devPIC663.o drvPIC663.o PIC663Register.o devPIE710.o drvPIE710.o PIE710Register.o devPIE516.o drvPIE516.o PIE516Register.o devPIE517.o drvPIE517.o PIE517Register.o devPIE816.o drvPIE816.o PIE816Register.o -lmotor -lasyn -ldbRecStd -ldbCore -lca -lCom -lpthread -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libPI.so
Installing library ../../../lib/linux-x86_64/libPI.a
make[3]: Leaving directory '/soft/epics/modules/motor-R6-10-1/motorApp/PiSrc/O.linux-x86_64'
I think this has nothing to do with removing of the upper line because it is located in line 313.
My C / C++ knowledge is poor, so i don't know if my drvPIE816.cc is corrupted... I always compile the whole motor-package and this is the only file causing errors.
Maybe its because of my Linux-System, some missing package? Can someone tell?
Von: Torsten Bögershausen <[email protected]>
Gesendet: Mittwoch, 18. September 2019 14:44:54
An: Sintschuk, Michael; [email protected]
Betreff: Re: Correct Settings for PIE816 Controller
I don't have this controller, but what happens if you remove
this line in drvPIE816.cc
On 18/09/19 11:21, Sintschuk, Michael via Tech-talk wrote:
Hello,
I'm using a one-axis piezo which is controller via the PIE816 Controller. I managed to set up an IOC which is communicating with the PIE816 and i also can drive the piezo axis. My problem is, that the motor is always in the "at HOME" status. The startup of my IOC is as follows:
~/expIOC/iocBoot/iocexpIOC> ./st.cmd
#!../../bin/linux-x86_64/expIOC
## You may have to change expIOC to something else
## everywhere it appears in this file
##cd /home/ptb/expIOC/iocBoot/iocexpIOC/
< envPaths
epicsEnvSet("IOC","iocexpIOC")
epicsEnvSet("TOP","/home/ptb/expIOC")
epicsEnvSet("MODULES","/soft/epics/modules/")
epicsEnvSet("ASYN","/soft/epics/modules/asyn")
epicsEnvSet("MOTOR","/soft/epics/modules/motor-R6-10-1")
epicsEnvSet("PSEUDOMOTORS","/soft/epics/modules/pseudoMotors-1-1")
epicsEnvSet("CALC","/soft/epics/modules/calc-R3-7")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
cd /home/ptb/expIOC
dbLoadDatabase "dbd/expIOC.dbd"
expIOC_registerRecordDeviceDriver pdbbase
# over TCP/IP
#drvAsynIPPortConfigure("PIE816", "193.149.13.40:10001",0,0,0)
# over Serial
drvAsynSerialPortConfigure("PIE816","/dev/ttyS0",0,0,0)
asynSetOption("PIE816",-1,"baud","115200")
asynSetOption("PIE816",-1,"bits","8")
asynSetOption("PIE816",-1,"parity","none")
asynSetOption("PIE816",-1,"stop","1")
asynSetOption("PIE816",-1,"clocal","Y")
asynSetOption("PIE816",-1,"crtscts","Y")
#asynSetTraceIOMask("PIE816",0,2)
#asynSetTraceMask("PIE816",0,255)
#asynOctetSetInputEos("PIE816", 0, "\r\n")
#asynOctetSetOutputEos("PIE816", 0, "\r")
PIE816Setup(1, 60)
PIE816Config(0, "PIE816", 1)
## Load record instances
dbLoadRecords("db/expIOC.db", "PORT='PIE816'")
#dbLoadRecords("db/beer.db")
cd "/home/ptb/expIOC/iocBoot/iocexpIOC"
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Jul 2 2019
epics>
the complete dadabase for my motor-record is:
epics> dbtr PIE665:Piezo1
ACCL: 0.5 ACKS: NO_ALARM ACKT: YES ADEL: 0
ALST: 0 ASG: ATHM: 1 BACC: 0.2
BDST: 0 BKPT: 00 BVEL: 0.1 CARD: 0
CDIR: 0 CNEN: Enable DCOF: 0 DESC: motor 1
DHLM: 1000 DIFF: 0 DINP:CONSTANT DIR: Pos
DISA: 0 DISP: 0 DISS: NO_ALARM DISV: 1
DLLM: 0 DLY: 0 DMOV: 1 DOL:CONSTANT
DRBV: -0.00434 DTYP: PIE816 DVAL: -0.00434 EGU: um
ERES: 1.0e-06 EVNT: FLNK:CONSTANT 0 FOF: 0
FOFF: Variable FRAC: 1 HHSV: NO_ALARM HIGH: 0
HIHI: 0 HLM: 1000 HLS: 0 HLSV: NO_ALARM
HOMF: 0 HOMR: 0 HOPR: 0 HSV: NO_ALARM
HVEL: 0.1 ICOF: 0 IGSET: 0 INIT:
JAR: 4 JOGF: 0 JOGR: 0 JVEL: 2
LCNT: 0 LDVL: -0.00434 LLM: 0 LLS: 0
LLSV: NO_ALARM LOCK: NO LOLO: 0 LOPR: 0
LOW: 0 LRLV: 0 LRVL: -4340 LSPG: Go
LSV: NO_ALARM LVAL: -0.00434 LVIO: 1 MDEL: 0
MIP: 0 MISS: 0 MLST: 0 MMAP: 0
MOVN: 0 MRES: 1.0e-06 MSTA: 2347 NAME: PIE665:Piezo1
NMAP: 0 NSEV: NO_ALARM NSTA: NO_ALARM NTM: NO
NTMF: 2 OFF: 0 OMSL: supervisory OUT:VME_IO #C0 S0 @
PACT: 0 PCOF: 0 PHAS: 0 PINI: NO
POST: PP: 0 PREC: 5 PREM:
PRIO: LOW PROC: 0 PUTF: 0 RBV: -0.00434
RCNT: 0 RDBD: 1.0e-06 RDBL:CONSTANT RDIF: 0
REP: -4340 RHLS: 0 RINP:CONSTANT RLLS: 0
RLNK:CONSTANT RLV: 0 RMOD: Default RMP: -4340
RPRO: 0 RRBV: -4340 RRES: 0 RTRY: 10
RVAL: -4340 RVEL: 0 S: 10000 SBAK: 500
SBAS: 500 SCAN: Passive SDIS:CONSTANT SET: Use
SEVR: NO_ALARM SMAX: 0 SPMG: Go SREV: 200
SSET: 0 STAT: NO_ALARM STOO:CONSTANT STOP: 0
STUP: BUSY SUSE: 0 SYNC: 0 TDIR: 1
TIME: 2019-09-18 11:11:49.238256323 TPRO: 0 TSE: 0
TSEL:CONSTANT TWF: 0 TWR: 0 TWV: 1
UDF: 0 UDFS: INVALID UEIP: No UREV: 2.0e-04
URIP: No VAL: -0.00434 VBAS: 0.1 VELO: 2
VERS: 6.1 VMAX: 0 VOF: 0
epics>
With this settings i can move the motor but for example you see that the ATHM field is 1, so at home. And the MSTA bits tell me that the home-limit-switch is hit and that the motor is not homed. How is a movement in both directions possible if the Status is "at home"?
Is there a way to home the motor properly via EPICS? I tried to set the HOMF / HOMR fields but nothing happens, they go back to 0 and the motor isn't moving.
My substitution file looks like this:
file "$(MOTOR)/db/basic_motor.db"
pattern
{P, N, M, DTYP, C, S, DESC, EGU, DIR, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, RDBD, PREC, DHLM, DLLM, INIT}
{PIE665:, 1, "Piezo$(N)", "PIE816", 0, 0, "motor $(N)", um, 0, 2., 0.1, .5, 0, 0.1, .2, 1e-6, 0.001, 5, 1000, 0, ""}
Maybe i took the wrong one, can someone help?
Thanks in advance!
Best Regards
Michael
- Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
- Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
- Re: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
- AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
