1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: areadetector NDArrayPool issues
From: Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
Date: Fri, 20 Sep 2019 10:28:38 +0000
I am running multiple prosilica cameras. Some camera crashes in 5 min while others run for 5-6 hrs. My guess is something to do with memory stuffs (alloc, dealloc, buffer size, stack size etc).  I am also using adPython plugin to do image processing using openCV. The error I get is –
NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f1a640010e0
Thread scan-1 (0x562a979bd2c0) can't proceed, suspending.
Dumping a stack trace of thread 'scan-1':
[    0x7fad8bb6db13]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(epicsStackTrace+0x73)
[    0x7fad8bb5d4e5]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(cantProceed+0xc5)
[    0x7fad8b136b6f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libADBase.so(_ZN11NDArrayPool7reserveEP7NDArray+0xdf)
[    0x7fad8b37f30f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x36f)
[    0x7fad8b3c315d]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats16processCallbacksEP7NDArray+0x3d)
[    0x7fad8b3c4164]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats10writeInt32EP8asynUseri+0xe4)
[    0x7fad8a844eab]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(writeInt32+0x3b)
[    0x7fad8a856085]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processCallbackOutput+0x25)
[    0x7fad8a823995]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(queueRequest+0x285)
[    0x7fad8a8566d9]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processLo+0x59)
[    0x7fad8c03fd38]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0xd8)
[    0x7fad8bdba34f]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbProcess+0x23f)
[    0x7fad8bdc8efb]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbPutLink+0x12b)
[    0x7fad8c0379d8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(execOutput+0x88)
[    0x7fad8c0380bf]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x5ef)
[    0x7fad8bdd5bb0]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(recGblFwdLink+0x10)
[    0x7fad8c037db8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x2e8)
[    0x7fad8bdcac14]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(scanList+0x64)
[    0x7fad8bdcafd8]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(periodicTask+0x1a8)
[    0x7fad8bb67dc8]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(start_routine+0xf8)
[    0x7fad894086db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[    0x7fad89d4988f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread scan-1 (0x55f358edc150) suspended
The version of EPICS and support modules are
a)       base – 3.15.6
b)      asyn – 4-33
c)       calc – 3-6-1
d)      seq – 2.1.21
e)      streamDevice – 2-6
f)        busy – 1-6
g)       areadetector – 3-5
1.       ADcore – 3-5
2.       ADsupport – 1-9
3.       ADprosilica – 2-5
h)      Adpython – 1-4 (https://epics.anl.gov/tech-talk/2019/msg00588.php)
The st.cmd file looks like
#   Prosilica driver
prosilicaConfig("$(PREFIX)CAM", $(CAMID), 50, 0)
dbLoadRecords("$(ADPROSILICA)/db/prosilica.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("ADBase.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
# Create ROI plugins
NDROIConfigure("$(PREFIX)ROI", $(QSIZE), 0, "$(PREFIX)CAM", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDROI.template", "P=$(PREFIX),R=ROI1:,  PORT=$(PREFIX)ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)CAM")
# Create a transform plugin
NDTransformConfigure("$(PREFIX)TRANS", $(QSIZE), 0, "$(PREFIX)ROI", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDTransform.template", "P=$(PREFIX),R=Trans1:,  PORT=$(PREFIX)TRANS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)ROI")
# adPython plugin for centroid
adPythonPluginConfigure("$(PREFIX)CENTROID", "$(TOP)/pythonScripts/adPythonCentroid.py", "Template", 10, 0, "$(PREFIX)TRANS", 0, 100, 50,1,200097152)
dbLoadRecords("NDPluginBase.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS,NDARRAY_ADDR=0")
dbLoadRecords("$(ADPYTHON)/db/adPythonPlugin.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID, TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS")
# standard arrays plugin
NDStdArraysConfigure("$(PREFIX)Image", 3, 0, "$(PREFIX)TRANS", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template","P=$(PREFIX),R=image1:,PORT=$(PREFIX)Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)OVER,TYPE=Int8,FTVL=UCHAR,NELEMENTS=1245488)")
Any way to fix this?
Many Thanks
Sandeep Malu
Prev: RE: EK9000 Device Support Dominic Oram - UKRI STFC via Tech-talk
Next: Re: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 20 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
