Hi Sandeep,
The stack trace indicates the problem is in NDPluginStats following a call to its writeInt32 method. That looks like it could be an issue that was fixed in ADCore R3-6. This is from the R3-6 release notes:
NDPluginStats
* Removed calls to processCallbacks() when CursorX, CursorY, or CentroidThreshold are changed. This is no longer thread safe. To see updates when plugin is not receiving NDArrays change the PV and then press ProcessPlugin.
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
Sent: Friday, September 20, 2019 5:28 AM
To: [email protected]
Subject: areadetector NDArrayPool issues
I am running multiple prosilica cameras. Some camera crashes in 5 min while others run for 5-6 hrs. My guess is something to do with memory stuffs (alloc, dealloc, buffer size, stack size etc). I am also using adPython plugin to do image processing using openCV. The error I get is –
NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f1a640010e0
Thread scan-1 (0x562a979bd2c0) can't proceed, suspending.
Dumping a stack trace of thread 'scan-1':
[ 0x7fad8bb6db13]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(epicsStackTrace+0x73)
[ 0x7fad8bb5d4e5]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(cantProceed+0xc5)
[ 0x7fad8b136b6f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libADBase.so(_ZN11NDArrayPool7reserveEP7NDArray+0xdf)
[ 0x7fad8b37f30f]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x36f)
[ 0x7fad8b3c315d]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats16processCallbacksEP7NDArray+0x3d)
[ 0x7fad8b3c4164]: /usr/local/epics/support/areaDetector/current/ADCore/lib/linux-x86_64/libNDPlugin.so(_ZN13NDPluginStats10writeInt32EP8asynUseri+0xe4)
[ 0x7fad8a844eab]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(writeInt32+0x3b)
[ 0x7fad8a856085]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processCallbackOutput+0x25)
[ 0x7fad8a823995]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(queueRequest+0x285)
[ 0x7fad8a8566d9]: /usr/local/epics/support/asyn/asyn4-33/lib/linux-x86_64/libasyn.so(processLo+0x59)
[ 0x7fad8c03fd38]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0xd8)
[ 0x7fad8bdba34f]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbProcess+0x23f)
[ 0x7fad8bdc8efb]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(dbPutLink+0x12b)
[ 0x7fad8c0379d8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(execOutput+0x88)
[ 0x7fad8c0380bf]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x5ef)
[ 0x7fad8bdd5bb0]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(recGblFwdLink+0x10)
[ 0x7fad8c037db8]: /usr/local/epics/base/lib/linux-x86_64/libdbRecStd.so.3.15.6(process+0x2e8)
[ 0x7fad8bdcac14]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(scanList+0x64)
[ 0x7fad8bdcafd8]: /usr/local/epics/base/lib/linux-x86_64/libdbCore.so.3.15.6(periodicTask+0x1a8)
[ 0x7fad8bb67dc8]: /usr/local/epics/base/lib/linux-x86_64/libCom.so.3.15.6(start_routine+0xf8)
[ 0x7fad894086db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[ 0x7fad89d4988f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread scan-1 (0x55f358edc150) suspended
The version of EPICS and support modules are
a) base – 3.15.6
b) asyn – 4-33
c) calc – 3-6-1
d) seq – 2.1.21
e) streamDevice – 2-6
f) busy – 1-6
g) areadetector – 3-5
1. ADcore – 3-5
2. ADsupport – 1-9
3. ADprosilica – 2-5
h) Adpython – 1-4 (https://epics.anl.gov/tech-talk/2019/msg00588.php)
The st.cmd file looks like
# Prosilica driver
prosilicaConfig("$(PREFIX)CAM", $(CAMID), 50, 0)
dbLoadRecords("$(ADPROSILICA)/db/prosilica.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("ADBase.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=$(PREFIX)CAM,ADDR=0,TIMEOUT=1")
# Create ROI plugins
NDROIConfigure("$(PREFIX)ROI", $(QSIZE), 0, "$(PREFIX)CAM", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDROI.template", "P=$(PREFIX),R=ROI1:, PORT=$(PREFIX)ROI,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)CAM")
# Create a transform plugin
NDTransformConfigure("$(PREFIX)TRANS", $(QSIZE), 0, "$(PREFIX)ROI", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
dbLoadRecords("NDTransform.template", "P=$(PREFIX),R=Trans1:, PORT=$(PREFIX)TRANS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)ROI")
# adPython plugin for centroid
adPythonPluginConfigure("$(PREFIX)CENTROID", "$(TOP)/pythonScripts/adPythonCentroid.py", "Template", 10, 0, "$(PREFIX)TRANS", 0, 100, 50,1,200097152)
dbLoadRecords("NDPluginBase.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS,NDARRAY_ADDR=0")
dbLoadRecords("$(ADPYTHON)/db/adPythonPlugin.template","P=$(PREFIX),R=Centroid1:, PORT=$(PREFIX)CENTROID, TIMEOUT=1,NDARRAY_PORT=$(PREFIX)TRANS")
# standard arrays plugin
NDStdArraysConfigure("$(PREFIX)Image", 3, 0, "$(PREFIX)TRANS", 0, 0)
dbLoadRecords("$(ADCORE)/db/NDStdArrays.template","P=$(PREFIX),R=image1:,PORT=$(PREFIX)Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PREFIX)OVER,TYPE=Int8,FTVL=UCHAR,NELEMENTS=1245488)")
Any way to fix this?
Many Thanks
Sandeep Malu
- areadetector NDArrayPool issues Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: AW: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
<2019>
2025
2026
Fw: areadetector NDArrayPool issues Mark Rivers via Tech-talk
<2019>
2025
2026
