1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: AW: AW: Correct Settings for PIE816 Controller
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Sintschuk, Michael" <[email protected]>, "Rivers, Mark L." <[email protected]>, Torsten Bögershausen <[email protected]>
Date: Fri, 20 Sep 2019 15:12:39 +0000
Here is info from Steffen Rau about limitations of the E-816:
“Compared to current GCS2 devices from PI,  E-816 has  limited
functionality. The basic commands (e.g. to position a stage and read the
sensors) are the same. But E-816 is an interface module and not a
digital controller, therefor many other features are not available for
the E-816 (e.g. acceleration, velocity, travel range,
homing/referencing). So it cannot really be “integrated” into the PI
GCS2 code but will need its separate class and most of the
implementations will simply be empty.”
I've closed the github issue and will continue to recommend that people
use the E-816 support from motorPI (https://github.com/epics-motor/motorPI).
Kevin
On 9/20/19 2:32 AM, Sintschuk, Michael wrote:
> Hi Kevin,
> thanks for the help! The old driver is working fine for me, so I stay with it for now.
> However if there will be a E-816 compatible EPICS PIGCS2 driver in future, I would change to it.
> Michael
Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Mark Rivers via Tech-talk
Prev: Re: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Next: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Next: Control System Studio (CSS) and PV Adrian martinez munera via Tech-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
