1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Base R7.0.2.2 VME_IO Parsing
From: Graham Cox - UKRI STFC via Tech-talk <[email protected]>
Date: Mon, 23 Sep 2019 09:48:29 +0000
Hello All,
I have discovered during the upgrade process from Base v3.14.x to v7 (specifically 7.0.2.2) that certain support modules do not work correctly.
I am experiencing issues with the parsing of VME_IO INP/OUT specifications (“#Cn Sn @parameter” format) during dbLoadRecords.
For example, the mrfioc2 support module defines a record as:
record(bo, "CLA-C16-TIM-EVG-01:ResetMxc-Cmd") {
    field( DTYP, "EVG")
    field( DESC, "EVG Reset MXC")
    field( OUT,  "#C S @EVG-01")
    field( PINI, "YES")
    field( VAL, "1")
    field( UDF, "0")
The OUT field of this record is acceptable to 3.14.12.5 but 7.0.2.2 kicks this out on dbLoadRecords due to the missing card and signal numbers.  A v7 ‘fix’ to this is to replace all “#C S” instances with “#C0 S0”.
Another support module defines a record as:
record(ao,"CLA-C16-IOC-CS-01:CENTRAL-SMONCONF40")
    field(DESC, "sys_mon config")
    field(DTYP, "ifc1210")
    field(OUT , "#C S0x40 @SMON")
    field(VAL , "0")
    field(PINI, "YES")
    field(PRIO, "LOW")
    field(FLNK, "CLA-C16-IOC-CS-01:CENTRAL-CORETEMP")
Again, this is acceptable to 3.14.12.5 but 7.0.2.2 kicks this out on dbLoadRecords due to the use of a hexadecimal format signal identifier.  A v7 ‘fix’ is to replace all hex specifiers with decimal.
Is this behaviour an intentional change from Base 3.14->7 ?  Or am I missing something here?
Graham
Re: Base R7.0.2.2 VME_IO Parsing Michael Davidsaver via Tech-talk
Prev: Re: AW: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
Next: Fw: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Fw: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Next: Re: Base R7.0.2.2 VME_IO Parsing Michael Davidsaver via Tech-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
