1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Base R7.0.2.2 VME_IO Parsing
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Graham Cox - UKRI STFC <[email protected]>
Date: Mon, 23 Sep 2019 07:11:47 -0700
On 9/23/19 2:48 AM, Graham Cox - UKRI STFC via Tech-talk wrote:
> Is this behaviour an intentional change from Base 3.14->7 ?  Or am I missing something here?
Yes, back in 2015 as part of my work on linking and locksets the parser was made stricter.
The numbers became non-optional, were required to be decimal.  This was released in
3.16.0.1 (in 2016).
Also on the subject of updates.  Around the same time I switched mrfioc2 from VME_IO
links to INST_IO.
> record(bo, "$(P)ResetMxc-Cmd") {
>     field( DTYP, "Obj Prop bool")
>     field( OUT , "@OBJ=$(OBJ), PROP=Reset MXC")
>     field( DESC, "EVG Reset MXC")
>     field( PINI, "YES")
>     field( VAL, "1")
>     field( UDF, "0")
https://github.com/epics-modules/mrfioc2/blob/1e703ba49944cd2137cd04641b80195347d1a404/evgMrmApp/Db/evgMrm.db#L35-L42
RE: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
Prev: Fw: areadetector NDArrayPool issues Mark Rivers via Tech-talk
Next: RE: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Base R7.0.2.2 VME_IO Parsing Graham Cox - UKRI STFC via Tech-talk
ANJ, 23 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
