Hi Kiman,
There are many different places which you can use in order to add them.
One example, you can put them in configure/CONFIG_SITE
USR_INCLUDES += -I/usr/include/CL
USR_LDFLAGS += -lOpenCL
PROD_LDLIBS += -lOpenCL
or
USR_LDFLAGS += `pkg-config --libs OpenCL`
PROD_LDLIBS += `pkg-config --libs OpenCL`
And you can also put the similar things in yourApps/src/Makefile where
you compile your source codes with opencl api functions.
Some hints which you may get in the following codes:
https://github.com/epics-modules/ecmc/blob/master/devEcmcSup/Makefile#L25
https://github.com/epics-modules/ecmc/blob/master/devEcmcSup/Makefile#L29
https://github.com/epics-modules/asyn/blob/master/asyn/Makefile#L36
https://github.com/epics-modules/ecmc/blob/master/configure/CONFIG_SITE#L38
HTH,
Han
On 9/26/19 4:15 AM, Ha, Kiman via Tech-talk wrote:
Hello All,
I have a plan to use the OpenCL API and library with epics IOC.
The platform is Linux 64bit.
My build option is to use the “xcpp” compiler instead of the “gcc”.
The “xcpp" compiler is Xilinx C++ compiler which is based on GNU
compiler collection.
With below build options:
CXXFLAGS += -std=c++14
LDFLAGS += -lOpenCL
My questions are:
1. Do I need re-build base using the “xcpp” compiler?
If yes, which base configuration files need to change?
2. Or only my IOC application need to add the OpenCL library with
"xcpp" compiler?
Kiman
- OpneCL and base and IOC Ha, Kiman via Tech-talk
Re: OpneCL and base and IOC Jeong Han Lee via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
