On 9/26/19 4:15 AM, Ha, Kiman via Tech-talk wrote:
Hello All,
I have a plan to use the OpenCL API and library with epics IOC.
The platform is Linux 64bit.
My build option is to use the “xcpp” compiler instead of the “gcc”.
The “xcpp" compiler is Xilinx C++ compiler which is based on GNU
compiler collection.
With below build options:
CXXFLAGS += -std=c++14
LDFLAGS += -lOpenCL
Hi Kiman,
I am sorry, I didn't focus your questions in my previous email.
My questions are:
1. Do I need re-build base using the “xcpp” compiler?
If yes, which base configuration files need to change?
If you need the cross compiler toolchain to compile the EPICS base,
you have to check it within
https://github.com/epics-base/epics-base/tree/7.0/configure/os
In base/configure/CONFIG_SITE, you can define
CROSS_COMPILER_TARGET_ARCHS in order to match your Xilinx toolchain.
If you cannot find one to match your own, you have to create one to
match your toolchain environment.
You can find almost every information in base/confgure/os. In
addition, the following path may help you to do so
https://github.com/icshwi/e3-base/tree/master/configure/os
2. Or only my IOC application need to add the OpenCL library with
"xcpp" compiler?
Yes, you only need OpenCL library, and (maybe) header files in your
IOC application makefile or configuration files, which I explained in my
previous email.
HTH,
Han
Kiman
- OpneCL and base and IOC Ha, Kiman via Tech-talk
Re: OpneCL and base and IOC Jeong Han Lee via Tech-talk
error binding socket Alfio Rizzo via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
