1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: motor-7-1 make errors
From: Ernesto Paiser via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 2 Oct 2019 16:24:00 -0700
Hello,
I'm trying to compile the motor-7-1 from synApps_6_1,
but after fixing some wrong files versions in
motor-7-1modules/RELEASE.linux-x86_64.local
and
motor-7-1/configure/RELEASE
asyn-R4-35  >>> asyn-R4-36
busy-R1-7-1 >>> busy-R1-7-2
ipac-R2-15  >>> ipac-2-15
I still getting this error:
>#motor-7-1/make clean; make
make -C ./modules install
make[1]: Entering directory `/opt/epics/extensionsTop_20120904/synApps_6_1/support/motor-7-1/modules'
make -C ./motorOms install
make[2]: Entering directory `/opt/epics/extensionsTop_20120904/synApps_6_1/support/motor-7-1/modules/motorOms'
configure/CONFIG:17: /configure/CONFIG: No such file or directory
configure/RULES_DIRS:2: /configure/RULES_DIRS: No such file or directory
make[2]: *** No rule to make target `/configure/RULES_DIRS'.  Stop.
make[2]: Leaving directory `/opt/epics/extensionsTop_20120904/synApps_6_1/support/motor-7-1/modules/motorOms'
make[1]: *** [motorOms.install] Error 2
make[1]: Leaving directory `/opt/epics/extensionsTop_20120904/synApps_6_1/support/motor-7-1/modules'
make: *** [modules.install] Error 2
It should be something obvious... but any hint??
Thanks
 Ernesto
Re: motor-7-1 make errors Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION J. Lewis Muir via Tech-talk
Next: Re: motor-7-1 make errors Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: fast PV transition skipped in EPICS 3.16 Reiter, Simon Patrik via Tech-talk
ANJ, 16 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
