1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base missing header files when using INSTALL_LOCATION
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Date: Wed, 2 Oct 2019 12:25:32 -0500
On 10/02, Ralph Lange via Tech-talk wrote:
> This thread is about older versions of Base. (And I wonder why Dirk is
> "always" installing old Base versions.)
:-) I don't know, but I would bet it's because change is the enemy of
reliability!  Each EPICS major and minor version introduces change that
breaks backward compatibility and introduces new features.  Even though
I wish for fewer backward-compatible-breaking changes, I do understand
and appreciate the effort to improve EPICS.  Still, moving to a new
EPICS major or minor version requires testing and fixing problems that
arise.  By remaining on the same EPICS major or minor version (i.e.,
upgrading along the patch version only), you avoid this pain.
I'm reminded of this IEEE Spectrum article which mentions the great
lengths engineers went to in order to not change some of their systems
on early Soyuz spacecraft:
  https://spectrum.ieee.org/view-from-the-valley/aerospace/space-flight/charles-simonyi-checks-out-the-soyuz-user-interface-on-the-way-to-space
Lewis
EPICS base missing header files when using INSTALL_LOCATION Abdalla Ahmad via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Ralph Lange via Tech-talk
Prev: CA Repeater Re: [EXTERNAL] Re: write a CA client by API in Eclipse Kasemir, Kay via Tech-talk
Next: motor-7-1 make errors Ernesto Paiser via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION Ralph Lange via Tech-talk
Next: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
