1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS on windows10 Debian Shell
From: Alfio Rizzo via Tech-talk <[email protected]>
Date: Tue, 1 Oct 2019 15:55:13 +0000
I guess I understood what was the issue with the binding socket I had.
(see my previous message “Error binding socket”)
I have installed a WSL Linux (Debian) Shell app on Windows10
to try to see if I can avoid to install a Linux VM on my laptop.
So actually I succeeded to compiled EPICS and run it,
with the native Debian GNU Linux compiler ( 8.3.0).
As it should be, the OS macro is defined as __linux__ not as _WIN32,
since the compiler is NOT MinGW or CYGWIN, but GNU as I said before.
So, then it comes issue I had was this UDP socket biding issue,
since binding is still handled a la Windows.
So the problem is in the source file blockingUDPTransport.cpp
where the macro _WIN32 is not used consistently in my case.
I tested to commented/uncommented the relevant code by the macro and indeed
It works as expected (no more bind socket error)
However I would like to know the opinion of the code developers (Marty Kraimer?)
and also if it would be possible to modify this file in a way
to include the option to use Windows way to handle UDP socket even if is a GNU compiler
(some ad-hoc env variable?)
Thanks
Alfio
PhD Alfio Rizzo
Control System Integrator
Integrated Control Systems Division
European Spallation Source ERIC
Telephone: +46(0)721792342
Mail Address: P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
https://europeanspallationsource.se/
essLogo
Re: EPICS on windows10 Debian Shell Michael Davidsaver via Tech-talk
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Next: Re: EPICS on windows10 Debian Shell Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION J. Lewis Muir via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
